Overheating issue 02 civic ex
Rep Power: 0 Overheating issue 02 civic ex
I have a 2002 honda civic ex with the 1.7l d17a2, my temp gauge fluctuates and starts to overheat when driving however its only occasionally, ive replaced the thermostat, radiator, radiator cap, headgasket, waterpump, flushed coolant, added new coolant and purged the system of air, i wired my cooling fans into a switch and have them running whenever the car is running and yet it still starts to overheat, typically at stops, then when i drive it will start to go back down but then sometimes its real weird and just flucuates like crazy, just the gauge goes up and then 10 seconds later it goes back down, and if i open the hood after this happens i can see where the coolant overflow had filled up and started overflowing, which i assume means air is getting into the system but i dont know how/why because the radiator is new and the cap is aswell, and i just replaced the headgasket, and i tested the thermostat to make sure it works and other than that i have no idea, the car gets good heat, and ive tried to fix anything i could think of that would be causing this issue, and ive also checked for leaks amd there are no signs of any other than where it overflows from the coolant overflow tank, so here i am, any help would be appreciated, thanks
Received 1,131 Likes
Rep Power: 192 Re: Overheating issue 02 civic ex
did you use an oem head gasket?
was the head checked by a machine shop?
did a competent person do the repair?
Rep Power: 0 Re: Overheating issue 02 civic ex
Yes, i used the oem metal one and yes, i had it checked and resurfaced, and i did all the work myself with the help of my uncle whos been working on hondas most of his life and im by no means a great mechanic but ive got a pretty good idea of what im doing, all the work ive done to the car i did myself as well as swapping it from an automatic to a 5speed
If you think you can convince us your head gasket repair was successful, your on the wrong forum because all the critical clues point to another failed head gasket.
Read up on the best test, injecting compressed air into spark plug hole on compression stroke and watch for bubbles coming out the radiator cap opening.
tifossi
07-14-2022 03:19 PM
SixAlpha
09-04-2018 08:52 AM
MarkoPollo
27
06-20-2018 02:45 PM
liagreenhalgh92
07-21-2015 01:31 PM
Shawn2340
05-19-2012 01:29 PM
