Overheating
Debvan
Rep Power: 0 Overheating
driving highway speeds for 30 miles and then within 1 mile after leaving the highway, temperature gauge starts rising. I changed thermostat and coolant sensor. Radiator fans come on when checked. Hose replaced 1 year ago. 1 fan replaced 3 years ago. Water pump and timing chain replaced 1 year ago.now what?
Debvan
Super Moderator
Received 1,836 Likes
Rep Power: 195 Re: Overheating
Is it leaking coolant? Is the coolant reservoir overflowing? GolNat's link will tell you everything you need.
Re: Overheating
Now it’s question of do you have a leak in the cooling system or do you have a leak in the head gasket.
At home without shop tools test way to diagnose is to start with a almost empty overflow tank and a full radiator and do your normal daily drive.
After everything is cooled down,
If the overflow is still almost empty and your radiator needs 2 more cups, your likely looking for a coolant leak somewhere.
If the overflow is filled up, likely your head gasket is leaking.
SixAlpha
09-04-2018 08:52 AM
SS22
08-22-2018 08:29 AM
katelyn85
10-08-2016 09:12 PM
Macalroy38
01-30-2015 01:10 PM
arizaga8799
10-17-2012 09:24 PM
