Overheating 1.7L
Overheating 1.7L
Ok guys & gals, 02 1.7L keeps overheating. 1st know what I have already done. All these are new and replaced. Temp control switch, thermostat, radiator, water pump, fans, timing belt & radiator cap. Also had an over night radiator pressure test on system and no psi lost. The last repair has been the water pump/ timing belt kit because pump weep hole leak found previously after adding dye and over heating. So, after this particular repair, added new coolant, burped system, car back up to circulating coolant, replaced cap, and test drove. Car overheated again around the block, returned to my garage, turn it off and inspected for leaks. NONE FOUND 🤔 Think I've spent more on repairs than car is worth but refuse to put a bullet to it.
what's next or what dud I miss?
Re: Overheating 1.7L
Overflowing out the coolant bottle?
head gasket, very common in these cars.
Go read and perform the test with shop air
https://www.civicforums.com/forums/3...reference.html
Combustion gases leak past head gasket into the water jacket. This pushes coolant into the coolant reservoir. Gases get trapped in the block which causes overheating.
Guess I start tearing motor apart but I'll double check by doing that test again. Thanks for the help, all information very useful. Just wished the certified mechanic I paid big bucks for would have been smart enough to look for that.
Roberto Smarr
Aug 18, 2019 10:23 PM
atkinson40
Aug 31, 2012 11:16 AM
rayhaque
Aug 5, 2012 06:50 AM
igor1979
Sep 17, 2009 07:25 AM
