Overheating or loss of coolant, heater blowing cold If you are having overheating of loss of coolant issues, post here!
Heater doesn't stay hot consistently.
Old Jan 7, 2021
Jaybron's Avatar
Jaybron
Jaybron is an unknown quantity at this point
So I just got this 05 Civic EX 5MT. The coolant reservoir fills up to the top by itself and the heater does not stay hy. I'm leaning towards replacing the radiator to see if that fixes the cooling/heating problem. I replaced the thermostat with a failsafe thermostat and the temp gauge is always closer to the cool side of the temp gauge. The reservoir fills up by itself and blows coolant out from the top which makes a mess. Thanks for any help. I'm about ready to get rid of this car if I can't get it to work right.
Old Jan 8, 2021
FRSam's Avatar
Click Here
Re: Heater doesn't stay hot consistently.
Head gasket
Old Jan 8, 2021
BrotatoChip's Avatar
Super Moderator
Originally Posted by Chezboat24
Head gasket
Unfortunately, he is likely correct. Here is a thread with some more info. This is an extremely common 7th gen issue.
https://www.civicforums.com/forums/3...reference.html
You'll almost certainly find the radiator coolant level low. Fill it up and drain the reservoir to the proper level. Bleed the coolant system by getting the front up high and letting the engine run with the radiator cap off, heat of full. If the head gasket is bad you will see a constant stream of bubbles coming out of the radiator. There are also a couple other test methods in that thread, definitely read it.
Old Jan 8, 2021
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Dang man, looks like this car needs a head gasket and clutch repair...
Old Feb 12, 2021
Jaybron's Avatar
Jaybron
I know. It runs surprisingly well though. If I don't slip the clutch it grabs and goes no problem.
So I got the front end up and bled the radiator and there was not a constant or semi constant flow of air bubbles coming out. My rad does look a little beat up so I'm going to replace that as I can get it for about 40 bucks.
Old Feb 13, 2021
this one spells headgasket, denial will not help you. Don't waste money buying a radiator.
Test it.
Old Feb 14, 2021
bachands's Avatar
bachands is just really nicebachands is just really nicebachands is just really nicebachands is just really nice
Based on this info, I would be about 99% certain the thermostat is STUCK OPEN. This would cause the engine temp to stay low and the heat to be lukewarm only.
The Failsafe thermostats are designed to stick open and stay open to protect the engine from overheating. Unfortunately, they tend to fail long before an overheating condition occurs and then they are stuck open for good. Crappy design. I know from experience...I went through two of them and BOTH failed open within a couple weeks of installing them.
SOLUTION
Get rid of the Failsafe thermostat and get a Stant or Gates brand. Napa and AAP typically sell Stant, while Rock Auto will sell both. Once you've done that, then see if you have problems and go from there.
Old Feb 22, 2021
Mathew Finlay's Avatar
Mathew Finlay is an unknown quantity at this point
Head gasket
I have same issue, however every coolant part has been changed other than the fan itself and a heater core. I can drive car around all day without it overheating but as soon as i put some jam into it or go up a large enough hill the temp starts going up and i lose my heat. Plugs are dry , coolant level is fine ( until it overheats and boils over ) , no white smoke, compression is fine, hydorcarbon test passed. No oil/coolant mix. When the temp goes to H like full are the fans not supposed to stay on until it reaches min spec?
Old Feb 22, 2021
Don't ask first. Start by reading.
couple posts above yours
Test it.
https://www.youtube.com/watch?v=bDHk...ature=emb_logo
Old Feb 22, 2021
EM2-EMMA's Avatar
I’m a guy. My car’s name is Emma.
EM2-EMMA is an unknown quantity at this point
I have the exact same issue. I replaced my failed thermostat with a Failsafe. I’m assuming this is the train of events that followed. My head gasket went bad (300k miles lol), and that caused overheating which prolly locked my thermostat open. I wasn’t sure so I replaced radiator. No help. Still overheated randomly and spewed out overfill. Replaced reservoir and bled system of air. It’s eradicated now for the time. Drove it hard then let it sit for 30 min. No issues. Will try new regular thermostat, and if it comes back i have a newly serviced engine ready to drop in.
Old Feb 22, 2021
the test on the video is easy. just do it and confirm if gasket or not.
If it does not pass, save money to do gasket.
Old Feb 22, 2021
EM2-EMMA's Avatar
dude you’re right. It’s gotta be head gasket. That would force air into the cooling system and fill the overfill reservoir and cause the air pockets which spike the temp and no heat through heater core. Thanks man
wasr10
Oct 31, 2020 10:01 AM
webster426
Air Conditioning
28
Jan 7, 2012 12:27 AM
motayba
Jan 4, 2011 01:07 PM
Earthson
Jun 17, 2009 11:32 PM
civiclee
Apr 7, 2007 02:12 AM
