Overheating or loss of coolant, heater blowing cold If you are having overheating of loss of coolant issues, post here!
Overheating, no coolant loss. Bogging down & sputtering after startup
Old Jul 22, 2021
Fortune42's Avatar
Fortune42 is an unknown quantity at this point
Sorry if this post is a redundancy. Plz forgive.
I have an 02' civic, manual trans, sedan. It was having major overheating issue that I traced down to the heater core. After flushing the core & radiator it cleared up a bit, but began to sputter & try to stall *after* starting, then it snaps out of it & runs fine. Will still overheat if idle too long, as I never hear fans kick on. 3rd gear seems to catch a bit & sometimes grinds. Theres rattling in the muffler & I assume its bad cat converter. -- any helpful advice is appreciated. Thanks
Old Jul 22, 2021
Re: Overheating, no coolant loss. Bogging down & sputtering after startup
https://www.civicforums.com/forums/3...reference.html
Old Jul 25, 2021
Wankenstein's Avatar
What method did you use to flush heater core?
What method/steps did you use to bleed air from the coolant system?
​​​​​​You may want to check for a failing/failed water-pump by removing the radiator cap while engine is cold. Let idle untile operating temp the rev engine slightly while looking into the radiator neck. Coolant current should move swiftly in one direction when the engine is revved once the thermostat opens. Keep as much distance from the radiator as you can while looking into the radiator neck and you may want to wear goggles.
byzelo
Jan 17, 2016 07:34 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
arbowman
22
Jan 3, 2014 09:09 PM
fallon
Jan 10, 2013 12:13 PM
Farage
62
Dec 14, 2005 12:50 PM
