Overheating or loss of coolant, heater blowing cold If you are having overheating of loss of coolant issues, post here!
01 ex blowing white smoke and misfiring
Old May 1, 2020
Fox_95's Avatar
Fox_95 is an unknown quantity at this point
Exclamation 01 ex blowing white smoke and misfiring
whats up i have a 01 ex with 192k miles. i replaced the front brakes spark plugs and coils the other day. i also replaced the IAT sensor because i had a p0113 code and the oil pressure switch needed changed but the p0113 code still there. Now my code reader wont work just beeps and says error. Did i possibly mess up my ecu changing out that iat sensor? Then i noticed a strong gas smell and found a hole in the muffler blowing black liquid out of it and blows alot of white smoke. I took it for a little test drive and after i got it to around 2k rpm it misfired alot then went away. Kind of feels sluggish and when i first started it up it almost died out. What could all of this mean?
Old May 1, 2020
Re: 01 ex blowing white smoke and misfiring
sounds like a classic case of blown head gasket..
Old May 1, 2020
antrmo's Avatar
antrmo is an unknown quantity at this point
agreed, white smoke usually a sign of coolant being in the cylinders , hence the misfires too.
check your coolant levels when the engine is cold, also can watch for air bubbles in the rad cap area.
Old May 1, 2020
Fox_95's Avatar
Figures especially at 192k. i'll look for more signs to see if thats the issue. what would cause the black stuff to shoot out though? It was like a gas/water mix
Old May 1, 2020
man, if it waited that long to pop, consider yourself lucky. lol
couldn't tell you on the black liquid shooting out tho, especially a fuel/water mix coming out the tailpipe
Old May 1, 2020
antrmo's Avatar
not sure on the black liquid? ,,sounds like just regular exaust/emmisions with carbon?
Old May 1, 2020
I was thinking that, too, but OP said it was an fuel/water mix. If it's missing that bad, could be a stupid amount of fuel making it into the exhaust stream along with post-cat condensation
Jessereinosas
Feb 18, 2014 08:55 PM
Toms49ers4life
Sep 6, 2013 08:33 PM
got2run5
Feb 2, 2012 10:30 PM
5.0calypso93lx
Oct 29, 2006 11:52 AM
supermex
Sep 3, 2005 05:18 PM
