Overheating or loss of coolant, heater blowing cold If you are having overheating of loss of coolant issues, post here!
04 Civic LX OVERHEATING
Old Jul 26, 2022
Bigtiny's Avatar
Bigtiny is an unknown quantity at this point
So I just put a new rebuilt cylinder head and replaced the water pump timing belt radiator thermostat radiator cap everything basically but my car still overheats when I come off the freeway please help
Old Jul 26, 2022
Colin42's Avatar
Re: 04 Civic LX OVERHEATING
Does the fan come on? Did you bleed it properly? Did you use oem parts?
Old Jul 26, 2022
do the test in the videos on the first post.
https://www.civicforums.com/forums/3...reference.html
It it pass, go to the other items, it's not the head gasket
If it does not pass, it;s the headgasket
Old Jul 27, 2022
Bigtiny's Avatar
yes the fans come on. I just seen videos on the proper way to bleed so I’m gonna try that today I did use one parts
Old Aug 12, 2022
pcardinal42's Avatar
pcardinal42 is an unknown quantity at this point
I'm just about to start replacing all these items this weekend because of an overheat issue. It's the typical head gasket symptoms. Talking to the previous owners buddy, he says he let the car operate at unsafe temperatures often. I'm hoping the block isn't cracked.
Odd question. Is anyone that's had overheating and bad head gasket still getting great mpg? I just got 471 miles on a tank of gas, put in 11.5 gallons for a 41 mpg tank! Really hoping it stays that efficient or gets better after the repairs.
Old Aug 12, 2022
Colin42's Avatar
Block may be damaged, tried doing the head, headgasket, waterpump, belt, etc on my '00 and it was still overheating. Put in a different engine and all is well.
Mycivic8
Oct 25, 2021 07:51 AM
Dffdixie
Jul 20, 2016 06:31 AM
Delino
Dec 29, 2014 11:18 PM
tinstar
Aug 29, 2012 01:13 PM
