Overheating or loss of coolant, heater blowing cold If you are having overheating of loss of coolant issues, post here!
2005 civic ex..back presuring and losing coolant
Old Sep 9, 2020
tg17517's Avatar
tg17517 is an unknown quantity at this point
i have a 2005 honda civic..it holds pressure and shows no leaks with a pressure test and there is no water in my oil and no oil residue in my overflow bottle....but it slowly loses fluid and back pressures it into and spits it out of the overflow bottle at high rpm and long journeys....im perplexed and looking for help....what would cause this if its not the head gasket( which it appears not to be and it was just changed about 25,000 miles ago as well)...would a faulty thermostat cause this? and it does not overheat unless i let the coolant get too low from losing it out of the bottle...also it has a new radiator cap as well
Old Sep 10, 2020
BrotatoChip's Avatar
Super Moderator
Re: 2005 civic ex..back presuring and losing coolant
It's the head gasket. Read up. Combustion gases leak past the head gasket into the water jacket. That forces coolant out into the reservoir, overflowing it after enough time.
https://www.civicforums.com/forums/3...reference.html
RustyShackle
42
Aug 19, 2016 12:46 PM
mizzxjessika101
Jun 3, 2016 11:58 PM
MPGhound
Oct 9, 2014 01:03 PM
melody2244
22
Jun 26, 2012 09:15 PM
