Coolant boiling through overflow W/O overheat
Old Oct 9, 2014
MPGhound's Avatar
MPGhound is an unknown quantity at this point
Hi I have been having coolant escaping boiling through the overflow and air in coolant lines, only when the engine seems to be under high stress (driving up steep hills to 9,000 ft.). The temperature seems to be stable and i have replaced the coolant temperature sensor. hoping it may be something other than head gasket, tested it with a block tester (results didnt show anything) but afraid it may be something that only is showing symptoms under high stress..? Any suggestions are appreciated. Thanks
Old Oct 9, 2014
Re: Coolant boiling through overflow W/O overheat
Is the radiator pressure cap in good shape and doing its job properly?
Head gasket.
Most will pass that test when blown. Yes the high load has a lot to do with it.
cferry7
Oct 3, 2015 04:33 PM
raymondxcho
Sep 29, 2015 09:00 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
Bruce2
Sep 21, 2015 08:01 PM
SolidHollow
15
Sep 13, 2015 11:18 AM
