OEM Headgasket
Old Oct 9, 2014
thecerealguy's Avatar
thecerealguy is an unknown quantity at this point
OEM Headgasket
Hi, I've been lurking the forums for a bit because I most likely have a head gasket problem. I was wondering if this is the OEM headgasket for a 2004 Honda Civic Si (EX). I am from Canada and the choices for auto parts here are slim. I was also wondering if you can reuse the head bolts when changing the head gasket. Everything is stock and has never been modded in any way.
https://www.autopartsway.ca/PartDeta...ead-Gasket-Set
Old Oct 10, 2014
mikey1's Avatar
Re: OEM Headgasket
i don't think that website sells OEM parts.....that looks like an aftermarket head gasket to me.....go to a honda dealership and buy one.....yes you can re-use the bolts
Old Oct 10, 2014
Re: OEM Headgasket
^What he said.
No online dealers in your end of the country? Run across the border to a US dealer?
http://torontohondaparts.com/
Old Oct 10, 2014
Re: OEM Headgasket
Hmm I checked that website and it offered Nippon Leakless and ishino stone for OEM headgaskets. I read a bit more and ishino and Nippon are both OEM suppliers. So I guess the head gasket set from auto parts way is actually an OEM set.
Old Oct 10, 2014
mikey1's Avatar
Re: OEM Headgasket
no its not the same as OEM,
they might claim it is "OEM quality".....or "OEM approved"
but its still not the same as an OEM honda gasket,
just look at the price difference between the two, that should tell you something, you get what you pay for, do you want to be replacing that gasket again in another 6 months or a year?.....in the long run how much money is that really saving you?
dish out the extra money now, its well worth it in the long run
Old Oct 10, 2014
Re: OEM Headgasket
Oh thanks, I didn't realize there was a difference. I just assumed that if it was made by the OEM supplier it would be OEM. I just called my local Honda dealership and they sell the head gasket alone for $62.90. They don't have a head gasket kit or anything. Do you think it is necessary to have the whole kit and replace all the other seals and gaskets that are included in a kit?
Old Oct 10, 2014
Re: OEM Headgasket
Maybe, maybe not. It's damn hard to tell, so why take the chance on a huge job like that?
CSB:
Just this week we had to get some LCA bushings for an Odyssey.....and Danger Zone was the only place on our side of the freekin PLANET that had some in stock that day.
They sent us their famous scary 'made-in-China' white boxes of parts.
Lo, and behold, they actually had the OEM bushings in them!!!! Right part numbers molded in and errthang! I'd have never thunked it would be, but it was.
You KNOW the Zoo employees could not tell us ahead of time what the parts were gonna be either.
Depends on how much you are going to do and how much you think you can get away with reusing.
Does the head have to be stripped for the machine shop? Is it going to get a valve job?? Are you going to pull the water manifold off the end? Are you going to pull the intake? Does it need a cam seal?
Dist. blank plug? (it's not in the set anyway, gotta get it separate)
There IS a head gasket SET available through the dealer, and it includes the valve stem seals if you want them. May need to be special ordered, but it is available.
Otherwise you have to buy the gaskets you need individually from the dealer, and you probably need to know ahead of time what all you are going to need LOL
If you have plenty of time you could take it apart and make a list of gaskets to get as the job progresses?
UltraHDGames
Jun 8, 2016 05:16 PM
thatcham
Sep 30, 2015 08:28 AM
Cam Diaz
Sep 28, 2015 08:34 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
h4ldol
Sep 10, 2015 12:25 PM
