Overheating or loss of coolant, heater blowing cold If you are having overheating of loss of coolant issues, post here!
Car overheating
Old Dec 13, 2017
Dez124's Avatar
Dez124 is an unknown quantity at this point
Exclamation Car overheating
I took my car to the shop, they bled my radiator out of the air bubbles. Replaced my cap too. Car stopped overheating for like a day or so now it's going back up. My thermostat was changed. It's leaking antifreeze somewhere because car is blowing out cold or lukewarm air. Someone help?
Old Dec 13, 2017
Dez124's Avatar
Re: Car overheating
2002 Honda Civic ex
Old Dec 13, 2017
mikey1's Avatar
Re: Car overheating
find the coolant leak and fix it....however a blown head gasket is most likely the root of your problem
Old Dec 13, 2017
Wankenstein's Avatar
Re: Car overheating
If it's leaking then low coolant level can cause an overheat. Overheats can cause a breached headgasket. The shop you brought it to should have performed a coolant system pressure test to find leaks. You can rent (free) a coolant system pressure tester from Autozone or O'Rielly's. The problem is those testers have universal fittings and don't always fit radiator or reservoir openings correctly and subsequently do not hold pressure properly.
Other possibilties for overheating include:
Radiator fan not coming on
Waterpump failing/failed
Thermostat stuck in closed position
Radiator blockage
Air in coolant
Did the shop mention the thermostat as a possibilty? How long does it take the engine to overheat from a cold start?
Old Dec 13, 2017
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Re: Car overheating
My vote would be another damn 1.7L headgasket is toast. May as well do the timing belt service at he same time.
Old Dec 13, 2017
Dez124's Avatar
Re: Car overheating
I had the pressure test done twice different times and they said it wasn’t my head gasket
Old Dec 13, 2017
Dez124's Avatar
Re: Car overheating
i had the pressure test done twice for the head gasket and both times said it wasn’t jeadgaskey
Old Dec 13, 2017
Dez124's Avatar
Re: Car overheating
Radiator blockage
Air in coolant
usually takes a bit. I’ll be driving for like 10-15 minutes then it will start
Old Dec 13, 2017
Re: Car overheating
Pressure test doesn't rule out a headgasket breach. There are several types/locations of breaches. A leakdown test is the gold standard.
Old Dec 13, 2017
Re: Car overheating
Bring it to a better mechanic.
A cheap place to start is thermostat replacement if you want to DIY.
Any leaking near the waterpump?
Old Dec 13, 2017
Dez124's Avatar
Re: Car overheating
i already replaces the thermostat. And i don’t know where water pump is lol
Old Dec 13, 2017
Dez124's Avatar
Re: Car overheating
where would it leak if it were a head gasket?
Old Dec 13, 2017
Re: Car overheating
A leak down test involves pushing air into the cylinders. Spark plugs are removed, attachment to a compressor that's screwed into the spark plug threads. If the head gasket is breached (blown) the forced air from the compressor will show up as bubbles in the radiator during the test.
The most telling symptom of head gasket issue is if there is no external coolant leaks but, there is coolant loss. Typically there will be coolant loss in the radiator combines with coolant gain or overflow in the reservoir.
Sometimes internal coolant loss (coolant getting into cylinders through a headgasket breach or crack in engine block or cylinder head) will show up as white smoke emitting the tailpipe/exhaust. Typically, is most evident on first start-up of engine.
Another possibly symptom of a head gasket breach is the car's interior heater works sporadically or not at all.
Are you checking (when engine is cold) the radiator daily for coolant loss?
Checking the reservoir level?
If it were mine I would rent (free) a Block Tester from O'Reilly's or Autozone, purchase blue test fluid $10. If the blue test fluid turns yellow or green exhaust gases are entering coolant system via head gasket leak.
A block test is only accurate if coolant is positive for emission gases and blue fluid turns colors. If test fluid remains blue there still could be a headgasket leak: http://www.agcoauto.com/content/news/p2_articleid/200
Video below:
specks
Jan 1, 2010 01:02 PM
Stachmo
Jan 5, 2006 11:09 AM
Michalo187
33
Nov 1, 2005 10:49 PM
specks
15
Feb 9, 2005 07:31 PM
BIGLIMPDOG
Feb 4, 2003 09:08 AM
