Overheating or loss of coolant, heater blowing cold If you are having overheating of loss of coolant issues, post here!
Cooling issues/temp sensor question
Old Mar 9, 2013
BotenRedWolf's Avatar
BotenRedWolf is an unknown quantity at this point
I've got an 05 EX, (i read the sticky on overheating too, but I've got a couple more questions) and over the last week it's been overheating sporadically. At first it only ran hot at low rpms and low speeds, if you revved it a bit, the temp went down. At the same time, heat wouldn't work at low revs, but would at higher. Now the heat never works, the car is almost constantly way over temp, but the cooling fans don't kick in. One of my questions is if the sensor that feeds the gauge and the sensor that feeds the fan relay is the same sensor or not, and to add that even at really high operating temp, the upper hose is hot and pressurized and the lower is, mostly, colder and limp. The overflow has been filling and overfilling/spilling onto the fans. I'm thinking and hoping it's only a t-stat since the car only has 73k miles and has, for the most part, been treated nicely. Any ideas? Thanks!
Old Mar 9, 2013
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
Re: Cooling issues/temp sensor question
Head gasket.
Overflowing reserve/overflow tank is a tell tale sign.
Do a search for blown head gaskets.
My story. https://www.civicforums.com/forums/3...ml#post4620666
Old Mar 9, 2013
Zed's Avatar
Zed
Zed is an unknown quantity at this point
Check the thermostat.
Old Mar 9, 2013
mikey1's Avatar
most likely a head gasket....
you could try changing the thermostat and rad cap first (USE OEM HONDA PARTS)....its not likely going to help, but no harm in changing them anyway after 7 years
Old Mar 9, 2013
I just drove it again, and this time it didnt go above 2/3 - 3/4 H and when cycling, the heat would lead the gauge by about 10 seconds. Again rpm independent.
Old Mar 9, 2013
Keep the dang radiator full before you ruin the engine and cost yourself far more than it was already going to cost for the head gasket job alone.
I bet the head is already warped.
Old Mar 9, 2013
Cars got a $5000 repair estimate from a wreck on it anyway. Think i might get rid of it. Get a different one.
7thgensurvivor
38
Aug 29, 2015 11:50 AM
juror
Jun 9, 2015 02:15 PM
juror
May 26, 2015 06:35 PM
bsmiley
Apr 27, 2015 01:27 PM
viper775
Dec 9, 2001 10:52 PM
