Overheating or loss of coolant, heater blowing cold If you are having overheating of loss of coolant issues, post here!
Something I did was wrong in bleeding cooling system [solved]
Old Jul 13, 2024
Robertlx's Avatar
Robertlx is an unknown quantity at this point
I bled the system twice. Bubbles still coming.What I may be doing wrong is turning the heater on before the radiator cooling fan kicks in. It may be cooling the coolant with the heater fan causing the radiator fan not to start.I ran the engine for 1/2 hour or more twice and still it was bubbling. So I'll try again and wait until the radiator fan starts then turn the heater on. I'm using a bleeder kit(no splash no mess large funnel). There's no smoke with the bubbles.
Old Jul 14, 2024
Colin42's Avatar
re: Something I did was wrong in bleeding cooling system [solved]
Leave the fan off, but have the heat all the way on
Old Jul 16, 2024
Robertlx's Avatar
I took the radiator cap off this morning ran the car through about 5-6 fan cycles and the bubbles disappeared..whew..103 degrees in Baltimore today..
theRedhatch
Jun 8, 2017 01:26 PM
valenzuela
Jul 19, 2008 12:46 AM
7thgencivicdriver
Aug 20, 2003 07:31 PM
CarbonFly
21
Feb 12, 2003 03:02 PM
