Overheating or loss of coolant, heater blowing cold If you are having overheating of loss of coolant issues, post here!
Overheating
Old Mar 29, 2021
Jeff Hite's Avatar
Jeff Hite is an unknown quantity at this point
Overheating
05 Civic changed water pump and thermostat and still overheats. How can I tell if it’s head gasket or radiator? Help please
Old Mar 29, 2021
GolNat's Avatar
Prelude Owner
Re: Overheating
Does the coolant back up out of the radiator overflow?
There is a sticky somewhere that explains the best way to check I thought.
Old Mar 29, 2021
Jeff Hite's Avatar
Re: Overheating
I just purchased the car 1 week ago and knew it needed a water pump. Replaced water pump then drove it around the block. Temp started rising, got it home and popped the hood. Checked and over flow tank was full. When I started to remove the cap there was pressure behind it and started to come out. That’s the only experience I have so far with driving it.
Old Mar 29, 2021
Colin42's Avatar
Re: Overheating
Head gasket, go read the sticky
Old Mar 29, 2021
Re: Overheating
moved to proper section.
(yeah, we do have a special section for overheating, for a reason )
Old Mar 29, 2021
CraigW's Avatar
Re: Overheating
You found the right site.
Old Mar 29, 2021
Re: Overheating
Test finished. Headgasket
https://www.civicforums.com/forums/3...reference.html
Old Mar 29, 2021
Jeff Hite's Avatar
Re: Overheating
What is the sticky? I’m new to this forum
Old Mar 29, 2021
Re: Overheating
the link i posted...
Old Mar 29, 2021
Jeff Hite's Avatar
Re: Overheating
Ok The over flow does start to fill up and with the motor off you hear a bunch of bubbling coming through the over flow. Which I would believe to be sign of needing a new head gasket. Is it worth it to fix or should I just eat my loss and try to find something else
Old Mar 29, 2021
FRSam's Avatar
Click Here
Re: Overheating
It’s worth fixing if you do it yourself. Otherwise, find a new car.
Old Mar 29, 2021
Colin42's Avatar
Re: Overheating
Only use OEM Honda parts, and get the head checked by a machine shop
Kevito
Dec 16, 2020 01:20 PM
Dccoleman
Jan 4, 2020 02:54 PM
Mastinarx
May 9, 2018 07:57 AM
98hondaciviclx
Oct 30, 2015 12:21 AM
Delino
Dec 29, 2014 11:18 PM
