Overheating or loss of coolant, heater blowing cold If you are having overheating of loss of coolant issues, post here!
Mystery coolant loss [solved]
Old Feb 17, 2021
relative4's Avatar
relative4 is an unknown quantity at this point
I have a friend with a 2004 Civic, LX I think. The coolant keeps running low, and I'm at a loss. I have replaced the lower radiator hose, and the thermostat and gasket. I can find no leakage in the engine bay, and the interior does not smell of coolant. I have pressure tested the system, and it holds pressure up to 20 PSI. Can anybody suggest what I'm missing? Thanks!
Old Feb 17, 2021
BrotatoChip's Avatar
Super Moderator
Re: Mystery coolant loss
Is the coolant reservoir gaining coolant and possibly overflowing? If so read the thread below, likely a bad head gasket.
https://www.civicforums.com/forums/3...reference.html
Old Feb 17, 2021
relative4's Avatar
Reservoir is not overflowing, and I forgot to mention I already did a combustion gas leak test, but that was a while ago; I should repeat it.
I also replaced the water pump.
Is a leaky reservoir hose a common culprit on these cars?
Old Feb 17, 2021
have you done this test?
Old Feb 18, 2021
Super Moderator
But is it overfilled? If symptoms are not severe yet it won't overflow but will be slowly gaining coolant.
Not really. If it were leaking you'd see remnants somewhere.
Do this. These engines often pass a combustion gas leak test.
Old Feb 23, 2021
relative4's Avatar
Thanks guys, you were right. Despite passing a combustion gas leak test and a 20PSI coolant system test, the head gasket is bad. I did a leakdown test, and cylinder 3 is pushing coolant. Bummer.
Oh yeah, and it turns out the reservoir is overflowing. Hard to get accurate information from the car's owner sometimes.
Old Feb 23, 2021
Re: Mystery coolant loss [solved]
next step: (image courtesy of our sage ezone)
Old Feb 24, 2021
Super Moderator
Thanks for updating the thread
We always recommend using a Honda genuine head gasket or you may have issues reappear sooner than you'd like. Also, get the head checked for warpage and get it milled if necessary.
Old Feb 24, 2021
and there were some issues with the tensioner, so be sure to install it properly
Jayonkin93
Sep 30, 2019 10:33 PM
WaryDriver
Dec 20, 2016 12:42 PM
MPGhound
Oct 9, 2014 01:03 PM
tatarik
19
Nov 29, 2012 01:47 AM
jasonkoller
Oct 17, 2011 07:56 PM
