Overheating or loss of coolant, heater blowing cold If you are having overheating of loss of coolant issues, post here!
Overheat/No heat
Old May 8, 2020
goffykates's Avatar
goffykates is an unknown quantity at this point
Overheat/No heat
I recently purchased a 2004 Honda Civic lx and the last owner complained of the car over heating and no heat. Drained coolant and got brown milky color. Could it be head gasket? Any help? Thanks.😁
Old May 9, 2020
antrmo's Avatar
antrmo is an unknown quantity at this point
Re: Overheat/No heat
sounds like head gasket, was coolant low? , air locks caused by the air in the coolant system would cause both no heat and over heating.
white smoke from exhaust? misfires? engine light? harder to start after cool down time?
Old May 11, 2020
goffykates's Avatar
I drove it home to realize not a drop of coolant was in in the radiator or reservoir poured in coolant and the heat worked fine but now it’s leaking oil and coolant when It runs so defenitly head gasket
Old May 11, 2020
BrotatoChip's Avatar
Super Moderator
These engines rarely leak coolant/oil when the head gasket has failed. It's usually combustion gases leaking into the coolant.
You need to narrow down where you're leaking both fluids from to determine.
Old May 11, 2020
Wankenstein's Avatar
Find out why there wasn't any coolant. Must be an external leak somewhere. Then replace the headgasket. Bring the head to a machine shop to mill flat, check for leaky valves, cracks. Check the engine block with a precision level and feeler gauge when the head is off. Use Honda genuine parts only.
Old May 13, 2020
goffykates's Avatar
The coolant is leaking from the engine coolant temp sensor which is gone and the oil from gasket thanks for all the help guy’s
Old May 15, 2020
Did you replace the head gasket?. If not, and it has overheated, it will most likely have a breach that will cause internal coolant loss.
Bbeja
May 8, 2019 02:50 PM
Jarrells
Jul 6, 2018 09:53 PM
Matthew Greene
Jul 1, 2016 12:59 AM
Bounddyy
Jul 8, 2015 11:22 AM
Stanged78
Feb 22, 2008 08:19 PM
