Engine overheating after changing thermostat and both coolant temp sensors
A few days ago I changed my thermostat, coolant temp sensor, and coolant fan temp sensor and now my car is running hot, around 210 degrees. I have to keep my defrosters blasting and keep the car moving or the temperature goes up to the 230 degree range. I've bled the air out of the cooling system already, I don't see any coolant leaks, there's no oil in my coolant and no coolant in my oil so I don't think it's a head gasket, I just changed the air filter today.. I'm considering putting the old sensor back in and seeing if that changes anything? IDK, I've run out of ideas. Please help
Platano3porpeso
Sep 15, 2017 11:18 AM
2002ExCivic
16
Nov 29, 2016 08:29 AM
ThatD_17
27
Oct 14, 2016 06:58 PM
arizaga8799
Sep 24, 2012 10:33 PM
