Overheating or loss of coolant, heater blowing cold If you are having overheating of loss of coolant issues, post here!
Head gasket
Old Aug 28, 2024
Treyfischer's Avatar
Treyfischer is an unknown quantity at this point
Head gasket
So I replaced the head gasket on my 2005 lx 1.7 non vtec with a aftermarket multi layer steel one and I did get the head machined but it’s still leaking into the coolant and yes I did torque the bolts to spec. So my question is, does anyone have a recommendation on a head gasket should I just use OEM? I heard that a certain Acura head gasket is better than a Honda. Should I go thicker or should I go with a more racing style head gasket because of them being designed for higher pressures. Thanks
Old Aug 28, 2024
CBM1992's Avatar
CBM1992 is an unknown quantity at this point
Re: Head gasket
Use OEM Honda whenever you can with these cars, down to the Type 2 coolant and DW-1 transmission fluid. They're particular little machines, but they'll treat you right if you do the same.
Old Aug 28, 2024
Colin42's Avatar
Re: Head gasket
The Acura part is just going to be the honda part.
Old Sep 3, 2024
BrotatoChip's Avatar
Super Moderator
Re: Head gasket
Head gasket part number is 25910-RPC-000 and can be had from Amazon for around $50.
Claydylan44
Oct 8, 2023 08:24 PM
alterman156
Mar 8, 2019 04:41 PM
Silver_JS5
Aug 17, 2004 11:40 PM
HondaCivicJosh
Engine Swaps
Aug 15, 2003 12:30 AM
Roy
Apr 12, 2002 11:11 AM
