Machining Cylinder Head
Hello all! New to the forum and hoping to learn and get useful inputs.
First for me doing a head gasket. Seems to be going good so far. I did this for preventive maintenance only since my 03 Civic has 221k miles and I don't want to wait til the head gasket blows to do it. Car still runs great when I started the teardown.
My question is do I take the head to the machine shop and get it serviced since there were no issues prior to this maintenance? If so, what type of work should I get done on it? This is a daily commute car, everything stock, maintained very well, and I've driven every single mile on it so I wouldn't want any fancy work done to the head like a race engine would get. Just looking for basic service. Any recommendations, thanks in advance!
Re: Machining Cylinder Head
take it in regardless to make sure it's flat. They can tell you if it needs to be machined or not. I think the tolerance for warping is something like .004" or something tiny like that.
Since you have the head off and you are doing it as preventative maintenance you may want to consider spending extra on it such as:
1) Milled flat (shaved)
2) New valve stem seals (inexpensive)
3) Valves checked for sealing and have them lapped (honed) and polished if need be.
4) Get the head hot tanked (cleaned).
It would be a good time to change the thermostat (Honda genuine only) if it has 50k miles or more on it. Also, replace the coolant,
But what is the reason to get valves “lapped (honed) and polished”? I see you mentioned if needed.
Since I’ve drained the coolant it’s bound to be replaced. Thermostat actually looks fine when I cleaned the water passage unit and changed seals on it too. Seems easy to get to if I need it later. Also, the car had zero issues whatsoever when I decided to do all of this. I will keep that thermostat replacement in mind though. Thanks for the helpful tips.
I understand reasons behind #1, 2, & 4. As for #3, I know sealing is good to get done. I’m actually replacing almost all seals and gaskets while I’m at this.
The best prevention of a breached head gasket is to prevent the engine from overheating. A new Honda genuine thermostat is worth the extra $30 and install time IMO.
matthew_burnett
Apr 14, 2012 03:01 PM
cbalthazor
Aug 7, 2011 10:22 AM
wardhaines
Jan 5, 2010 09:39 PM
