Overheating or loss of coolant, heater blowing cold If you are having overheating of loss of coolant issues, post here!
Coolant loss
Old Aug 29, 2019
DGG's Avatar
DGG
DGG is an unknown quantity at this point
Coolant loss
2001 Honda Civic ex, Auto tranny 188k miles. I’m losing coolant without any puddles under the car. Block test was clean, oil is clean, no sweet smell in exhaust . Recently replaced cam sensor, valve cover comes off during, everything looked good. Burped cooling system by letting it run with heat on full blast while topping off coolant in radiator until level stayed the same, filled reservoir to max, no bubbles once the level stayed the same. Drove for an hour parked it, coolant level didn’t drop. Drove it 30+ miles the next day, coolant didn’t drop. Took the cap off and checked level in radiator and it was good. Next day coolant dropped in reservoir by more than half, rad level was still good. Burped and topped it back off today, presumably issue will repeat. ANY HELP??? SUGGESTIONS??
Old Aug 30, 2019
Slumpertcivic's Avatar
Re: Coolant loss
What do you mean by “next day”? Was the car driven or parked?
Car stayed parked, take the radiator cap off the next night. If the reservoir drops again it has a crack, if it’s full and the radiator level dropped you have a leak.
If the car was driven , and you have a completely full coolant system and a overfilled reservoir, then as the coolant heats up it will push coolant out of the reservoir. Once the system cools, it will pull back that coolant and you will have a air gap again in the reservoir. That’s why your not expected to fill it past the bottom line when cold.
Old Aug 30, 2019
DGG's Avatar
DGG
Re: Coolant loss
Car was driven 30+ miles parked for the night. Checked after drive and when cooled down, no loss. Next morning over half down. No puddles under the car. Was filled hot.
Old Aug 30, 2019
mac25's Avatar
Dr Krieger of Modification
Re: Coolant loss
Headgasket breach, drinking coolant? (Usually these blow coolant out of the reservoir though)
The reservoir can stay on full while the coolant is hot, even if the coolant is being consumed. Then when it cools inside the radiator it will pull coolant from the reservoir.
Old Aug 30, 2019
DGG's Avatar
DGG
Re: Coolant loss
Checked hot and cold and didn’t lose coolant until it sat a night. I don’t have a clue
Old Aug 30, 2019
BrotatoChip's Avatar
Super Moderator
Re: Coolant loss
When you filled it with the cap off and heat on did you also raise the front of the car? Maybe an air pocket is still trapped in the system?
Old Aug 30, 2019
DGG's Avatar
DGG
Re: Coolant loss
No I didn’t not, do you think and air pocket would make it lose more than half from the reservoir to the rad? I’m about to check and see if any is lost today.
Old Aug 30, 2019
DGG's Avatar
DGG
Re: Coolant loss
Dissent appear to have lost any since I burped and filled yesterday, been drove the same distance. Only difference is when I checked last time before it lost coolant I took the rad cap off and checked. Not going to this time and going to check again tomorrow to see if any has been lost. Idk
Old Dec 31, 2019
kt2182's Avatar
kt2182 is an unknown quantity at this point
Re: Coolant loss
Please help I bought an 02 civic with only 145,000 miles. I started having issues with the car overheating and blowing coolant out the overflow tank, and the heater blowing out cold air when the temperature gauge starts rising. I replaced the radiator, radiator cap, thermostat, water pump, head gasket, overflow tank, both upper and lower hoses, and both coolant temp sensor and fan sensors. I drove it for a few days and the heater stopped blowing out hot air again and coolant sprayed out the overflow tank, and the heater stopped blowing out hot air again. The temperature gauge did not move but I am still very concerned. This can not just be an issue that I can not fix, so can someone please assist me with what more I can do?
Old Dec 31, 2019
Colin42's Avatar
Re: Coolant loss
Either you didn't bleed the coolant properly, or when you did the headgasket it wasn't done properly (head wasn't machined, non OEM gasket used, etc)
Old Jan 6, 2020
kt2182's Avatar
Re: Coolant loss
Sent the head to get machined, and used OEM gasket, bled the system following proper instructions. There was never an issue with the headgasket, I just replaced the water pump and decided since I was doing all that I might as well do the head gasket. There is absolutely no signs that the head gasket was cracked or warped. I have pressure checked the engine which there are no issues. There has got to be some where else that that fluid could be getting air and over pressurizing.
Old Jan 6, 2020
Colin42's Avatar
Re: Coolant loss
How did you bleed the coolant?
Old Jan 7, 2020
pjb3's Avatar
pjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of light
Re: Coolant loss
When you say you 'have pressure checked the engine', do you mean the standard radiator pressure test or Ezone's test where each cylinder is pressurized to at least 150 psi and the radiator is checked for bubbles?
Old Jan 7, 2020
kt2182's Avatar
Re: Coolant loss
topped off the radiator fluid, turned the car on and turned the heater on, then ran the engine until the fans kicked on twice and topped off the fluid until the bubble came to a minimum and fluid stopped going down.
Old Jan 7, 2020
kt2182's Avatar
Re: Coolant loss
Sorry didn't mean to say engine, pressure tested the cooling system and held pressure.
Old Jan 7, 2020
Colin42's Avatar
Re: Coolant loss
Need to get the nose as high as you can and use a spill free funnel
Need to pressurize each cylinder to 150 psi or more and watch for bubbles coming out of the rad
Old Feb 4, 2024
Kc512njr's Avatar
Kc512njr is an unknown quantity at this point
Re: Coolant loss
Hi Kt2182, I'm new to this however. I'm going through the same issue. Could you tell me how you ultimately fixed this?
Old Feb 4, 2024
Colin42's Avatar
Re: Coolant loss
Most likely your headgasket
Old Feb 4, 2024
Kc512njr's Avatar
Re: Coolant loss
I appreciate you responding thanks. I've been consistently burping my 02 civic every 2 weeks. New thermostat, new radiator, new radiator cap, water pump 2 years old only 20k on it, system holding pressure, no signs (NONE) of a head gasket, and YES the front end is raised on blocks every time. I burp it, it's good for about two weeks, then starts blowing cold, starts to over heat, then I burp again and fine. I have to add coolant every time, but cannot find a leak. And holding pressure.
Oil is not milky, no smoke from trail pipe, no gurgling in radiator or reserve.
Old Feb 4, 2024
Colin42's Avatar
Re: Coolant loss
Read and perform the test in here with compressed air
https://www.civicforums.com/forums/3...reference.html
These cars don't fail in the typical way for headgaskets.
Old Feb 5, 2024
Super Moderator
Re: Coolant loss
The only other option that could cause air to get into the system is an external coolant leak. But you say there are no signs of a leak. Fluid level in the coolant reservoir would be key.
Old Feb 5, 2024
Kc512njr's Avatar
Re: Coolant loss
Good morning, thank you for the reply. So I double checked the coolant res. This morning and it was slightly above the MAX line. I burped again yesterday, and everything is fine now. But this is what happens, this will last 1 1/2 to 2 weeks and then I have to burp again. I have a question, does the length of time signify anything. It looks like most head gaskets, or people with almost the same symptoms, People are losing coolant fast, and mine is literally almost 2 weeks exactly.
Old Feb 5, 2024
Re: Coolant loss
go to the link posted, read it and watch the videos in the first post. Don't spend time in anything else other than doing the tests posted there.
that will stop your denial.
Old Feb 5, 2024
Kc512njr's Avatar
Re: Coolant loss
Lol you're absolutely right. This has all been great. The only difference I noticed was the length of time.
Anyone on long Island able to do this job? I don't think I'll be able too.
Old Feb 5, 2024
Super Moderator
Re: Coolant loss
The head gasket leak can start small and worsen over time. Unless you can find a small external coolant leak, I would believe it's head gasket.
Old Feb 5, 2024
Kc512njr's Avatar
Re: Coolant loss
Ok, understood. Thank you all.
I believe this may be our of my skillset.
If anyone would be available to quote doing this job I'd appreciate it.
Old Feb 5, 2024
FRSam's Avatar
Click Here
Re: Coolant loss
Entirely depends on whether your head’s warped or not. You’ll have to call around.
Old Feb 5, 2024
Kc512njr's Avatar
Re: Coolant loss
Copy that. Thank you for the heads up.
Old Feb 5, 2024
Super Moderator
Re: Coolant loss
A shop will probably charge $1-1.5k for a head gasket job. You're a long ways away or I would offer.
Qrenden
Sep 2, 2019 08:17 AM
WaryDriver
Dec 20, 2016 12:42 PM
djaysin04
Feb 2, 2009 02:02 PM
savedadogs
May 11, 2006 04:32 PM
cdmx
Mar 12, 2003 11:28 PM
