Coolant Level
Old May 11, 2006
savedadogs's Avatar
savedadogs is an unknown quantity at this point
Coolant Level
Hi All,
Just had the car serviced and liquids topped off in December. I checked my coolant today and it is on the MIN mark. Is this normal? That is how often do I need to fill the coolant? Also where can I buy the coolant...I looked at my manual and it says I have to use Honda All-Season Antifreeze/Coolant Type 2.
Thank you
Old May 11, 2006
tavdawg's Avatar
tavdawg is an unknown quantity at this point
Your coolant level should be on the low mark when the engine is cold. Pretty much coolant is coolant. If you have the green stuff then get the pre mixed (50/50) green stuff. If its orange then get the orange stuff. But also check the coolant level in your radiator just make sure the engine is cold when you do it. I believe the level should be up to the filler neck.
styles234
21
Nov 19, 2019 07:23 AM
cferry7
Oct 3, 2015 04:33 PM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
raymondxcho
Sep 29, 2015 09:00 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
