Overheating or loss of coolant, heater blowing cold If you are having overheating of loss of coolant issues, post here!
coolant system problem
Old Apr 7, 2011
philshonda's Avatar
philshonda is an unknown quantity at this point
i have a 2005 honda civic ex. the main issue i'm having is that it is blowing coolant back out through the reservoir and does it only when i'm driving on the interstate or anywhere really just when i'm at higher speeds. its not over filled that i know of because its blowing enough out to cause it to occasionally run hot on me. but i haven't been able to figure out the cause of the problem.
i have changed out the radiator and thermostat already.
so any help would be much appreciated. thanks
Old Apr 7, 2011
BlueEM2's Avatar
Whachya lookin at?
Re: coolant system problem
Your head gasket has failed and needs replacement. I am 100% sure this is your problem
Xuhme
21
Aug 7, 2023 03:40 PM
thana
Jun 15, 2020 07:05 PM
blazebrown
18
Jun 2, 2019 12:31 PM
Youshoe
May 22, 2015 09:36 PM
tylerginevan
Apr 27, 2015 12:29 PM
