Overheating or loss of coolant, heater blowing cold If you are having overheating of loss of coolant issues, post here!
Head gasket = P0336 ?????
Old May 29, 2021
jimperry6315's Avatar
jimperry6315 is an unknown quantity at this point
only code i got is p0336. puts it into limp mode. Excessive cooling system pressure blew cap off last night. Could i have leaking head gasket ??? compression is good in all cylinders, but how did that pressure get into cooling system? exhaust gases?
i get a little bit of sputtering from engine at 2300 rpms. Any help is appreciated.
Old May 29, 2021
FRSam's Avatar
Click Here
Re: Head gasket = P0336 ?????
Excess coolant through the overflow reservoir? That’s a bad head gasket.
Old May 30, 2021
Wankenstein's Avatar
Do a block test on it. Tester is a free rental at parts store and fluid is $10. If the blue test fluid turns green or yellow then exhaust gases are entering the coolant. However, a block test doesn't rule out every type of head gasket breach.
Compressed air 150 psi into one cylinder at a time at top dead center with the radiator cap off to inspect for air bubbles is probably the best test for head gasket breaches. Chezboat stated the best symptom to look for. That symptom can also be caused by a bad radiator cap in an open style coolant system.
I generally start with a block test as it cheap and easy to do and is accurate when exhaust gases are in the coolant.
Old May 30, 2021
https://www.civicforums.com/forums/3...reference.html
Old Jun 12, 2021
after market Crank Position Sensors do not work!!!!!!!! anyone reading this take heed. i can't believe they sell them nationally, but putting in OEM honda part solved all
my problems!
Old Jun 12, 2021
my problems!
Not surprising about an aftermarket part not working. There's a lot of garbage parts nowadays that are a quarter of the price of genuine OEM but don't work correctly or last long.
How did a crank sensor solve excessive coolant in the overflow reservoir issue?
Old Jun 14, 2021
BrotatoChip's Avatar
Super Moderator
wardhaines
17
Jun 16, 2019 02:49 PM
alterman156
Mar 8, 2019 04:41 PM
Unit562
Dec 28, 2014 10:00 PM
redright9
27
Feb 1, 2011 05:32 PM
Roy
Apr 12, 2002 11:11 AM
