Coolant leak
Coolant leak
I got a 03 civic ex that has had overheating problems since I had it. Replaced the head gasket about 15k miles ago and it’s been running fine. Recently I’ve noticed it has been overheating and the coolant is disappearing. At first I thought it was a head gasket problem so I just kept filling it with coolant while I was getting ready to replace it. During that time I decided to fix the thermostat because it was a cheap and easy. It seemed to work for a couple weeks and I had no problems. Then it recently started doing it again. When I was coming out of auto zone to get coolant I noticed it leaking. When I saw what was leaking it was coolant. It’s only leaking when it’s parked on a hill or angle. I was wondering if anybody else had this problem and knew what it was? I was thinking it could be a water pump or maybe I put the thermostat housing in wrong?
Re: Coolant leak
then do this test.
If passes, check other stuff
there is a list of thinks here
https://www.civicforums.com/forums/3...reference.html
vreozz
May 15, 2023 07:47 AM
Db2004
Nov 20, 2020 03:59 PM
ThatD_17
27
Oct 14, 2016 06:58 PM
byzelo
Jan 17, 2016 07:34 PM
mikey1
16
Jan 27, 2014 04:17 PM
