Overheating or loss of coolant, heater blowing cold If you are having overheating of loss of coolant issues, post here!
Overheating don't know why
Old Apr 27, 2020
Jamesholland3's Avatar
Jamesholland3 is an unknown quantity at this point
I've done a compression test and it's good.
New thermostats installed.
New waterpump installed.
New radiator installed. (Previous owner used stop leak)
Bypassed heater core to see if it was a clog issue didn't change anything
Put in a dual fan setup from a parts car cause mine only had one fan. Flushed the engine with a garden hose got gunck out then ran clear water for like 5 min.
I noticed fans don't stay on long.
It over heats when driving not at idle.
Any idea what it could be. I hooked everything buck up right and their still no hot air out the vents internally. Oil looks fine. No bubbles in radiator.
Old Apr 27, 2020
Colin42's Avatar
Re: Overheating don't know why
Could be more stop leak clogging up some of the water passages
Old Apr 27, 2020
BrotatoChip's Avatar
Super Moderator
What's the coolant level in the reservoir doing? Bad headgasket? The last 7th gen I had could idle for hours without any problems but if I drove it 2 miles down the road the reservoir was almost overflowing. It was a bad headgasket.
SuperEF
Jun 24, 2015 11:53 PM
mhillips
Aug 5, 2013 06:07 PM
mhillips
Jul 28, 2013 10:41 AM
dkdontforget
Jul 14, 2012 07:46 PM
BIGLIMPDOG
Feb 4, 2003 09:08 AM
