Overheating or loss of coolant, heater blowing cold If you are having overheating of loss of coolant issues, post here!
Coolant loss
Old Apr 30, 2020
Peter1961's Avatar
Peter1961 is an unknown quantity at this point
Coolant loss
Hi,I own a 2003 Honda Civic 1700 LX.
In January I had a new radiator and thermostat fitted,as the old radiator was cracked at the top.Today I noticed that the fans were on,and the temperature gauge was slightly above half way,it’s normally just below half way.I checked the coolant,and had to top up the radiator with about a quarter of a pint of coolant,and the expansion bottle by about half a pint,any idea what’s going on,thanks!
Old May 1, 2020
BrotatoChip's Avatar
Super Moderator
Re: Coolant loss
Head gasket problems are common on this generation Civic. Keep an eye on the coolant levels in both the radiator and reservoir. If the radiator level drops but the reservoir increases that points to a bad head gasket. If the level in both drops that points to a coolant leak, you should see evidence of this.
Old May 1, 2020
Peter1961's Avatar
Re: Coolant loss
Thank you for your reply,there is no creamy deposits around the inside of the oil filler cap,or on the dipstick,so I’m hoping it’s just a leak somewhere,a hose perhaps,a friend thinks it might be the water pump,but I had that replaced 3 years ago!
Old May 1, 2020
Colin42's Avatar
Re: Coolant loss
These cars don't show the common head gasket symptoms, pay attention to what brotato told you
Old May 1, 2020
Peter1961's Avatar
Re: Coolant loss
I will,thank you!
Sumeet Sahu
Oct 27, 2019 07:07 AM
Macalroy38
Jan 30, 2015 01:10 PM
webster426
18
Nov 30, 2011 09:18 PM
benjamin.civic
Sep 8, 2011 03:52 PM
streetglower
Jan 13, 2006 09:04 AM
