PDA
View Full Version : Electronics
Pages : [1] 2
  1. Can't seem to update 2015 Civic Sport head unit firmware via USB?
  2. no vehicle menu help
  3. Vehicle menu
  4. Eld
  5. How to set date after dead battery
  6. U0155 – Engine Light & Battery Light
  7. IMID Display Not Dimming (2015 Civic SI)
  8. Airbag Off sign
  9. Can you buy a key fob programmer?
  10. TPMS problem
  11. AUX connector is missing and i have 2nd AUX unit in Center console
  12. Airbag sensor issue
  13. Hey, is there any saftey percautions or measures I have to take to Swap out Seats?
  14. Dash Light for Radio not Working
  15. hello, honda civic
  16. Gauge cluster
  17. Frustrating, intermittent SRS Error B0001-13 -- any ideas?
  18. 2015 Civic Check Airbag System Code B000213
  19. Radio RDS
  20. Radio code for civic fd
  21. 06 Honda Civic: Auto-Dimming Rear View Mirror, W/Compass [solved]
  22. Wiring issue activating immobiliser Civic 1.5 D 2013
  23. Google maps stops speaking through hands free link port
  24. 2008 Civic Ignition Stuck
  25. Tachometer
  26. Can’t program key fob—mechanic installed new key module, did not program old key fobs
  27. anyone knows the min. speed for Civic 2010 to deploy air bag?
  28. 2012 Honda coupe not showing mileage
  29. Car radio stuck on H (honda civic type r fk2)
  30. HDS Software
  31. Issues/question with 8th gen key fob
  32. 2008 Honda Horn won’t stop blowing
  33. 2008 Civic Upper Dash Display Cluster [solved]
  34. Canadian Radio Code
  35. SRS Alarm civic gen. 9
  36. 2011 Civic Radio station LED lights not working!
  37. Odd TPMS Behavior
  38. SRS light Civic 2013
  39. 2006 Civic key copying
  40. 2007 Civic LX: Fuel gauge intermittently inverted
  41. Key transponder problem
  42. Cluster test
  43. 2008 civic hybrid speedometer
  44. 2010 Civic Coupe rear speakers
  45. key fob programming
  46. Replace or can a control module be reprogrammed?
  47. 2006 MK8 Windows and doors stopped working
  48. Need help with these airbag codes please
  49. Rear lights turning off problem
  50. Civic hatchback 2011 fn2 display clock
  51. Chirping sound
  52. Can Civic 2015 made compatible with Android Auto?
  53. Airbag parts
  54. 2012 Civic/alarm issue
  55. 2013 Honda civic...check air bag system
  56. Tpms option not selecting but have electrical fault codes too
  57. Fuel Gauge/Instrument cluster issue
  58. 07 Civic Coupe Airbag Replacement/Reset
  59. Issue that affects vipers, stereo display, and speedometer
  60. Fuel gauge not working 2015 Civic SE
  61. Instument cluster 12345 -9999 service light
  62. Keyless entry not working
  63. DSP off
  64. Lost resets on radio after battery replacement
  65. 2014 EX Sedan Keyless Entry Issue
  66. honda civic 2014 1.8L
  67. Need SRS unit
  68. 2009 civic climate controls not working
  69. Honda Civic 2015 smart entry
  70. Cruise Control is weird.
  71. 07 EX: rear speakers blown by front speaker pro install?
  72. Radio on, display working, but no sound
  73. Accidental Airbag Deployment
  74. Radio Code
  75. Honda Civic 2012 Sedan Side Curtain Airbag Deployed
  76. Radio in 2010 civic not working
  77. Key Fob will not open trunk, Second Key Works
  78. ABS?VSA and power steering lights on [solved]
  79. Drivers Side Seat Replacement - airbag sensors
  80. Keyless Entry Issue w/2015 Civic
  81. Green key flashing intermittently
  82. AirBag replacement
  83. Lost All Keys - Key Programming
  84. 2013 Honda Civic SI Factory Radio Wiring Harness [solved]
  85. 2013 FK2 R18 engine ecu swap
  86. Navigation error
  87. Fuse for Dashboard lights for clock radio
  88. Radio swap question.
  89. Anyone have a copy of their navigation dvd or not using one???
  90. 2014 Civic EX Gas Cap Loose Message
  91. Clock set via navigation
  92. Speedometer not working
  93. Keyless trunk release
  94. Alarm is off 2011 Civic EXS
  95. ATT message on cd player screen
  96. Is it possible pull a Computer log of what time my door was opened?
  97. Canadian '07 5-spd DX-G Coupe - key/fob (re-)programming
  98. 8th Gen Civic 2010, Handsfree takes over whole car
  99. 2013 Civic radio won't put out sound (not a speaker problem)
  100. 08 Civic LX sedan Aux problems
  101. Hissing sound after installing aftermarket stereo
  102. How do I set up my phone to play music in my 2008 civic?
  103. Clock and date and year reset problem. [cause found, need solution from Honda]
  104. Airbag deployed
  105. 2013 Honda Civic door unlock programing
  106. Radio problem - no AM, FM, CD, or AUX sound
  107. Radio and Key fob
  108. 2007 Civic - Immobilizer not recognizing key (green flashing key light)
  109. Left pillar tweeter not working sometimes
  110. Flashing green Key light 09 civic
  111. 2008 Civic Aux Problem
  112. 2009 FA5 Radio changes by itself.
  113. Car Alarm Problem
  114. Civic Radio
  115. 2015 Civic LX aux issues - randomly stops playing
  116. Speedometer isn't working
  117. 8th Gen. - Top centre display glitchy
  118. Where is USB?
  119. Car clock
  120. 09 Civic non-start after repairs [solved]
  121. Is there a way to set aftermarket rpm/mileage cluster to read correct mileage?
  122. 2015 Honda Civic SE (or LX) Key Reprogramming Issue
  123. Stock stereo volume not as loud as it used to be.
  124. 2007 Honda civic Aux problems
  125. 2007 Honda Civic ex
  126. 07 Cabin Fuse Box Swap Results in Flashing Green Key [solved]
  127. Dimming lights
  128. 2009 honda civic accelerate pedal issue
  129. Honda Civic MK8 2007 alarm module location
  130. key fob only works when car is parked in the sun
  131. 2007 Civic cant able to program key remote
  132. key only working intermittently
  133. Generation 9 Dashboard lights
  134. Immobilizer issues PLEASE HELP
  135. Help! Car Won't Start!
  136. ECU replacement
  137. Car throwing codes and I can’t decipher them - ‘12 Civic LX Coupe
  138. Problem
  139. Any way to bypass the vehicle maintenance reminder?
  140. 888 speedometer reading
  141. 2012 Honda Civic aftermarket radio installation
  142. Warning Indicator During turn
  143. 2008 EX Cope.. Wire harness layout, lost rear audio
  144. Ecu 06 civic
  145. 2006 Honda Civic not Unlocking
  146. Need help on my 8th civic
  147. 2007 Honda Civic alarm going off.
  148. Cruise Control
  149. 2013civic si center consul usb cable not working, and how to fix interior backlight
  150. 2015 Honda Civic Smart Entry Issues
  151. Re: Help...cruise control module?
  152. Head Unit Software Update Error
  153. 2015 Honda Civic Hybrid - LaneWatch
  154. 2015 Civic Airbag Fault
  155. 5 min delay timer circuit for the trunk light
  156. 2006 honda civic hybrid audio issues(turns off when turning up)
  157. Steering wheel Controls don't work - 2012 civic hybrid
  158. Immobilizer Issues
  159. Srs reset.. 2007 civic
  160. Keyfob only unlocks, does not lock or open trunk.
  161. P01113
  162. Radio trouble , need help plzz
  163. Help! 2008 civic (running)headlights stay on
  164. 2012 civic ex
  165. Navigation update 2014 Civic i-DTEC 1.6 Sport (EU)
  166. 2008 Civic Coupe [solved]
  167. 2007 Civic Hybrid - Help to diagnose Electrical fault please
  168. Head unit install gone wrong? Was already aftermarket setup
  169. 2006 civic ex coupe STEERING WHEEL CONTROL METRA AXXESS ASWC-1 HELP!!!!!
  170. Honda civic 2009 - I need help turning off the lock/unlock beeping sound
  171. Civic dashboard diagnostic
  172. ES-T Radio Security Code
  173. replaced 2006 honda civic ex radio with xm now no sound
  174. Help! 2008 Honda Civic no start and will not communicate with ECU
  175. Clock runs extremely fast
  176. Stereo components 2007 honda civic lx 1.8l
  177. SRS code help please
  178. DRL warning light illuminated
  179. Issue with blinker on one side, blinks fast and dim.
  180. Radio possessed
  181. Ignition key stuck at position 1, can't be turned anticlockwise to be taken out from
  182. Keyless entry stopped working
  183. Airbag/ weight sensor
  184. Speedometer not showing while car is on
  185. Need aux help
  186. 07 Honda Civic, Radio Locked via Code??
  187. Turns On, Turns Off, green key symbol flashing
  188. temp gauge on the dash stuck on high heat
  189. Faulty fuel gauge .
  190. Honda HIM vs other Honda scanners
  191. Air bag
  192. Check airbag system pop up and light
  193. SRS light questions
  194. Key fob wont program in my honda civic
  195. 2008 Civic LX Alarm Question
  196. CIVIC 06 airbag light on
  197. Anti Theft gone haywire
  198. HELP! issue with alarm
  199. OEM radio swap
  200. 2008 Honda Civic Coupe EX Rear Speaker Install
  201. Speed sensor & Imobilizer issues in 2010
  202. airbag codes
  203. airbag lite
  204. car AUX problem - very complicated
  205. 2008 Civic EX Coupe /w Navigation, but the AUX tab never shows up.
  206. DRL Warning Light
  207. Flashing green key light...
  208. Code throwing machine!😎
  209. TPMS light on and off
  210. 2010 Honda civic LX SRS RECALL
  211. “Passenger Airbag off” indicator light on problem
  212. Odormeter Reads Zero Miles After Alternator Replacement - Car had 195k Miles
  213. Airbag light
  214. Air bag question on 2015 Civic
  215. 2012 Civic EXL TPMS Issue
  216. Honda civic 2006 battery dead (immobilizer issue)
  217. 2012 i-MID issue/service bulletin 13-017 question
  218. My dash keeps flashing the word "no"...
  219. Airbag System
  220. VSA + ABS + iShift warning lights - get stuck in gear
  221. 2015 Civic fob
  222. Random beeping noise while driving
  223. Radio sound stop working?
  224. Best OBDII for 2006 Honda Civic Sedan (CDN)
  225. Key programmers - replacing Key '08 Civic
  226. unintended acceleration
  227. ABS and Brake System dashlights on after changing LCA's and draining battery
  228. 2011 alarm randomly going off when car parked
  229. 2014 Civic Air Bag Light
  230. 2001 civic dx, dash brake light staying on
  231. whine aux cable noise engine helppppp
  232. Alarm problem
  233. Cuise Control
  234. Honda Civic 08 - SRS light On
  235. Does my 2007 Civic have a immobilizer on the ignition switch?
  236. 2008 Cruise control quits
  237. Green Key Light, A/C and Radio problems and other oddities!
  238. Which parts of TPMS sensor assembly can be "re-used" when putting in new sensors?
  239. Anti theft system
  240. Remote part works, but the car won't start (green key light)
  241. Intermittent SRS airbag light (2006 Civic) Solutions? TSB?
  242. 2006 Honda Civic LX 4DR - SRS Module Model Number
  243. Honda Civic Alarm(need to disable)
  244. 2006 Civic will only start with OBD connected
  245. Airbags, airbags - how to replace, how much does it cost (approx)?
  246. Replacing ECM
  247. Passenger seat Weight Sensor SRS light
  248. alarm help!
  249. No sound from ipod thru the usb. Please help
  250. green key light
