Electronics Post information/questions/Issues about Electronic parts here.
U0155 – Engine Light & Battery Light
Old Jun 15, 2025
foary's Avatar
foary is an unknown quantity at this point
I am trying to find out why I’m getting a U0155 code. My battery light is on as well as my engine light and I almost feel as if they’re related. The battery light doesn’t come on until the car starts and cycles through its startup procedure. I can’t reset my oil life due to no communication between the cluster.
Things I’ve tried to eliminate the battery light:
- New Battery Voltage Sensor
- New Battery
- Cleaned connections
Car is a 2015 Civic SI. Any suggestions?
Old Jun 16, 2025
FRSam's Avatar
Click Here
Re: U0155 – Engine Light & Battery Light
Sounds like either a bad cluster or PCM that isn't communicating with the other modules. That's what the code means anyway. Since you've cleaned some connections, you'll either have to dig further or get it professionally looked at.
I'd bet money on the PCM, but confirm before buying anything.
traze77
Jun 6, 2016 07:29 AM
whwaldron04
Sep 11, 2013 10:24 AM
popee
Nov 2, 2007 11:49 PM
ManUtd0018
Nov 2, 2006 11:41 AM
encryptedband
Nov 15, 2005 07:42 PM
