Electronics Post information/questions/Issues about Electronic parts here.
2012 Honda Civic aftermarket radio installation
Old Nov 18, 2020
Xbrittany1x's Avatar
Xbrittany1x is an unknown quantity at this point
Does anyone have an accurate wiring diagram for the 2012 Honda Civic LX? I'm getting frustrated trying to find one. I want to make sure it is 100% correct before soldering the wires. I was going off of pin hole diagrams instead of the color, because the colors were not correct. I found a diagram, but it doesn't seem to be correct, either. It has things in pin holes that mine does not have anything in.
Old Nov 18, 2020
Colin42's Avatar
Re: 2012 Honda Civic aftermarket radio installation
Did you not buy the adapter harness?
Old Nov 18, 2020
No, the radio came with the one for that, and I am keeping the factory one in the car. That is why I am going off of pin holes and not colors. So, if you have somewhere I can find the diagram it would be much appreciated. Thank you
Old Nov 18, 2020
Colin42's Avatar
No there's a harness that directly plugs into the factory connector that you then solder/crimp connectors to the harness that came with the stereo. That way you don't have to hack the factory wiring and can easily return to stock. It's like $20, probably less if you're in the states.
Old Nov 18, 2020
I already have the factory one AND the stereo one. What I am saying is that I don't know which wire should be soldered to which wire. I NEED a CORRECT diagram for a 2012 Honda Civic LX. That's it. So let me know if you know where to find one. The ones that came with the stereo are labeled correctly, whereas my stupid factory ones are not labeled. I suppose I could buy a brand new one. If it is labeled for me that would make it incredibly easy.
Old Nov 19, 2020
Colin42's Avatar
Ok sorry didn't realize you had the adapter harness. Your post made it sound like you didn't.
You only need 7 wires to run the stereo, red, yellow, black, and the 4 pairs for the speakers (purple, green, grey, and white)
Orange is illumination which we typically don't recommend connecting
There's a blue and white which is for a a sub or a powered antenna, again not typically used.
What wires are you stuck on?
Old Nov 19, 2020
BrotatoChip's Avatar
Super Moderator
Pictures always help.
cfauvel
General 8th & 9th Gen
Dec 14, 2018 06:52 PM
lacrossedad
Dec 21, 2016 01:19 PM
Jordan Chiasson
Oct 9, 2015 01:22 PM
M_O_III
Mar 20, 2014 03:36 PM
WICKEDPHOTO
North East
Mar 11, 2012 11:59 PM
