Electronics Post information/questions/Issues about Electronic parts here.
Ignition key stuck at position 1, can't be turned anticlockwise to be taken out from
Old Dec 6, 2019
sdraza1's Avatar
sdraza1 is an unknown quantity at this point
Honda civic 2010. Ignition key stuck at position 1, can't be turned anticlockwise to be taken out from ignition though can be turned clockwise to turn on the engine. Thanks for the help
Old Dec 6, 2019
BrotatoChip's Avatar
Super Moderator
Re: Ignition key stuck at position 1, can't be turned anticlockwise to be taken out f
Is the key an original one?
Old Jul 27, 2022
acidangel77's Avatar
acidangel77 is an unknown quantity at this point
Probably not the original key, This has happened to me once too. What I did to get it out was basically wiggle the key while going forward to start then towards off..It worked for me and can maybe work for you. If that is the only key you have, I'd suggest calling a locksmith or your cousin juan for the hook up. I just called the locksmith. Good luck.
:AA:
Youngrob650
Nov 12, 2015 11:01 PM
resume-writer
15
Feb 16, 2015 09:13 PM
StudebakerJim
May 28, 2014 11:30 PM
o0oWunCivic
Nov 8, 2006 04:57 PM
PHILLYCIVICROB
Aug 21, 2006 03:58 PM
