Electronics Post information/questions/Issues about Electronic parts here.
2015 Civic Airbag Fault
Old Jul 14, 2020
canst's Avatar
canst is an unknown quantity at this point
Hi,
New to this forum and need your help.
I just bought 2015 Civic which has airbag light on and mechanic scanned and got this message "open or increased resistance in driver airbag second inflator".
Please let me know how to approach this. Appreciate your reply.
Old Jul 14, 2020
BrotatoChip's Avatar
Super Moderator
Re: 2015 Civic Airbag Fault
Created your own thread. You can have them clear the fault and see if it comes back. Otherwise it sounds like the airbag needs replaced.
Old Jul 14, 2020
canst's Avatar
Thanks. Mechanic did reset but light come back on after few kms. Now i start the car and light is off. So it is doing off and on. Code was B002 driver side second inflator increased resistance. Where is second inflator on driver side.
Old Jul 14, 2020
Super Moderator
The airbags have two inflators, both are located inside the airbag itself.
Old Jul 14, 2020
canst's Avatar
Thanks for information. Can i change driver side airbag inflators here (not myself but asking) or buy full airbag cover.
Old Jul 14, 2020
Super Moderator
Steering wheel airbags are usually not difficult to remove. The battery should be disconnected for ~10 minutes beforehand to avoid accidental inflation. I'm sure a replacement airbag would be expensive though, like $700. You could always call a service center and see if they could help you out. Sometimes they'll replace SRS components for free. I believe they did this on 7th gens with seat belt buckles.
saves
Aug 22, 2018 12:02 AM
ACG
Nov 7, 2015 09:49 PM
crazyasian
Nov 26, 2006 02:19 AM
HC2001
Jul 1, 2005 10:28 AM
CIVIC2NV
Jul 15, 2003 12:12 AM
