Electronics Post information/questions/Issues about Electronic parts here.
2013 Honda civic...check air bag system
Old Feb 28, 2023
Madamek's Avatar
Madamek is an unknown quantity at this point
Hi...so I hit something in the road that went under my car..ripping off the oil protective thing..drove four hours without noticing a problem..but then started hearing weird rubbing noise...I think I figured out that part...but then my check air bag light came on..earlier in the day my check emissions systems light came on and I ended up needing a thermostat...but now all sorts of lights are coming on...I drove all day today without that light coming on but it came on tonight..so drove back to AutoZone to have it checked again with the light showing ...but nothing came up.....I made an appt for a week from now but am kind of worried..has anyone had their airbag light come on...I checked the engine for rodent poop ...saw none..looked at a bunch of wires and don't see any wires chewed.....could that hit of a plastic thing somehow have messed up the air bag system?
Thanks so much!
Kirsten
Old Mar 1, 2023
BrotatoChip's Avatar
Super Moderator
Re: 2013 Honda civic...check air bag system
You will have to get underneath to look for damage.
Autozone reads codes for free but only powertrain faults (engine/transmission). You have to find someone with a better scanner to read SRS codes.
Old Mar 1, 2023
Madamek's Avatar
So it is possible that from something going under the car even if it was just a small plastic thing that it could mess up something on the air bag thing? Like maybe a sensor or something?
Thank you for responding...we aren't seeing anything underneath but we have been looking only at the wheel area and the noise
Old Mar 1, 2023
Colin42's Avatar
Take it in to the dealer
Old Mar 2, 2023
TomSchaeffer's Avatar
TomSchaeffer is an unknown quantity at this point
Originally Posted by Madamek
So it is possible that from something going under the car even if it was just a small plastic thing that it could mess up something on the air bag thing? Should I've checked my airbag before through the vin check? https://epicvin.com/vin-decoder Like maybe a sensor or something?
Sure, even a small plastic thing could cause some problems on the airbag
Old Mar 4, 2023
there are several sensors around the front of the car, some wires could have been pulled, or the sensors knocked out of place
Old Jun 21, 2023
coolmellowdude's Avatar
coolmellowdude is an unknown quantity at this point
GEN 9 CIVIC likely other models. Replace the Clock Spring on the steering column if one or more seatbelts locked (needs reset) and NO airbag deployment. The clock spring has a resistive fuse that blows if no crash sensor activated to disable driver airbag from deploying. Typical incident such as hitting a curb or pothole and breaking the wheel.
anwarma
Electronics
Jun 15, 2019 07:56 PM
greenlantern20
Jun 28, 2014 10:18 AM
2003hondacivic
Jan 15, 2004 10:36 PM
big20ugly
Nov 11, 2001 08:30 PM
