Electronics Post information/questions/Issues about Electronic parts here.
2008 Civic Coupe [solved]
Old Mar 20, 2020
comptuertech82's Avatar
comptuertech82 is an unknown quantity at this point
Question 2008 Civic Coupe [solved]
Premium stereo system. Having issues with the back speakers and sub suddenly not working. Right front still works. I think the left front might have a loose wire. The 3 speakers in the back is my concern. Is there some type of reset button, fuse that somehow affects all 3 speakers? I found a amp fuse under the hood, but it doesn't seem broken. I'm not sure, but the amp might be in the back right panel of the car. The trunk can only see part of it, mounted in the frame. help!
Old Jun 13, 2020
re: 2008 Civic Coupe [solved]
Ouch ZERO answers? Seems the right speaker has gone out as well now. So just the 2 tweeters in the far front can be heard. So it doesn't seem to be a fuse.
Anyone know if there is a pre-amp?
Old Jun 15, 2020
BrotatoChip's Avatar
Super Moderator
Unfortunately most of us don't have experience with 8th and 9th gen Civics. The only schematics I can find online are for the 2006 model and don't even show a sub. Here's what I can tell you though, there shouldn't be any amp/ground/fuse that would only affect the rear speakers/sub. The first thing I would check is continuity through one of the rear speakers with a meter, should see 4 or 8 ohms. If you don't see anything the speaker is bad.
Also ensure the fader hasn't accidentally been applied towards the front.
Old Oct 21, 2020
123Krash's Avatar
123Krash is an unknown quantity at this point
No help, but I have the same issue with my 2008 Civic EX Cpe., premium sound system no Navigation system... while searching came across your post.
Audio in front right/left speakers, maybe an issue with one of the tweeters, but in the rear I have no sound R/L or the Sub.
I have run the simple Diag. Radio power off, press and hold 1&3, power on brings up a simple sound test. Skip to move thru FR, FL, RR, RL, Sub, and alll to verify
Sound in front, no sound in rear.
There must be a common point somewhere causing this, its not likely that all 3 rear speakers are blown.
Old Oct 21, 2020
Super Moderator
There is a common point, the radio. I'm leaning towards an internal fault in the module.
Old Oct 21, 2020
123Krash's Avatar
That would really suck...
Old Nov 4, 2020
123Krash's Avatar
Seems like there is another common point the external Amp... in the '08 Coupe located under the front part of the console in front of the gear shift lever.
50/50 chance either way not inexpensive, wish I still had my old Oscilloscope.
Old Jan 6, 2022
Well, i did finally find out. Seems the speakers were 'getting old' and drying out. When my wife would play it loud, a speaker would give out. Took several weeks/months for most to finally fail. Had to replace just the speakers to fix the issue.
vboss5764
Apr 22, 2021 11:08 PM
Newbie Noah
General 7th Gen
Aug 8, 2016 06:46 PM
mf150
Dec 7, 2009 12:24 AM
smiley405
Jul 18, 2009 02:12 PM
WiseRabbitSays
Mid Atlantic
16
May 6, 2008 08:00 AM
