Electronics Post information/questions/Issues about Electronic parts here.
Honda civic 2009 - I need help turning off the lock/unlock beeping sound
Old Feb 11, 2020
hondacivic0901's Avatar
hondacivic0901 is an unknown quantity at this point
Angry Honda civic 2009 - I need help turning off the lock/unlock beeping sound
Hello, I have a Honda civic 2009 coupe and this lock/unlock beeping sound annoys me a lot because it's so loud. Every time I lock the car it beeps once and when I unlock the car, it beeps twice. Originally my car didn't beep, but after I went to a mechanic my locking system change. It doesn't seem like they could fix it, so I'm coming here for help!! My car has the fob which is separate from my actual key and I tried holding down my lock and unlock button for 2 seconds which turns on my hazard light 3 times(what it said on google). That didn't work. Any other suggestions?
Old Feb 12, 2020
BrotatoChip's Avatar
Super Moderator
Re: Honda civic 2009 - I need help turning off the lock/unlock beeping sound
So you have an aftermarket keyless entry system? The OEM key fob is part of the key. You will likely have to find out what system you have and look up instructions.
Old Feb 13, 2020
The name is rubbed off, so I can't find what one it's from. Is there any way to find out? Any other suggestions I could do to fix this beeping sound?
Old Feb 27, 2020
John the hat's Avatar
John the hat is an unknown quantity at this point
This may help..my alarm was going off on its own I disconnected the electrical connection at the bonnet (hood) catch. Now the lights flash but no bleeping. I think the alarm may be off too
Old Mar 5, 2020
which electrical connection is it? is this located under the hood?
Old Mar 5, 2020
which electrical connection is it? is it located under the hood?
Old Mar 5, 2020
Its connected to the bonnet catch. Take the plastic cover off follow the wires plastic connector undo it.
That stops the alarm going off. Lights still flash when you lock unlock the car. Well it did on mine I hope it does what you want.
Old Mar 6, 2020
PROBLEM SOLVED, thank you
Rawr.monsters
Feb 28, 2016 11:05 AM
bmnot
Jul 25, 2011 03:42 PM
redrazr
Dec 9, 2009 10:53 AM
CrazyKnight
Nov 30, 2005 10:36 AM
