Lost resets on radio after battery replacement
Re: Lost resets on radio after battery replacement
I am in the same situation:
I try the above link, the first thing it ask for is the VIN no., I enter the no., it says "Incorrect VIN numbered entered". but I did enter the right VIN
is the above link only for Honda USA? what if the car is in Honda Canada?
I believe you can also call he dealer and they will give it to you. With your vin, I think.
On mine, 2015 I didn't need a code. Just a reset of the presets. I still haven't figured out why that is.
On my 2004 (rip) I had the code in the glove box book, which came with it new.
dc
dc
I know that. The dealer is rude, they won't answer. So I thought Honda has to have a way to fix this, because a dealership can go belly up. honda still have to back its customers
As to the VIN, you have to put the letters in either upper case, or lower case. I can never remember. You have to try each to see which it is.
As to the code, try doing it a different way. You may not be doing the process right.
As I say, my 2015 works without the code. I have yet to figure that out or hear any explanation.
dc
dc
The VIN shouldn't matter if it's upper or lower case.
"The VIN shouldn't matter if it's upper or lower case".
Shouldn't. Didn't in California, but now I've moved out of California. And where I'm at now, it does.
dc
dc
MW35
Dec 14, 2017 05:02 PM
DB in Cbus
May 10, 2014 12:23 PM
fcs
Dec 17, 2013 12:44 PM
coachdiver
Aug 6, 2010 04:03 PM
