Is it safe to remove the battery on a 2008 Honda Civic 2.2 diesel Type S
Old Dec 14, 2017
MW35's Avatar
MW35 is an unknown quantity at this point
Can someone tell me is it safe to remove the battery for charging on a Honda Civic 2.2 diesel 2008, or will I damage computers, lose radio code etc. Thank you
Old Dec 14, 2017
Re: Is it safe to remove the battery on a 2008 Honda Civic 2.2 diesel Type S
Of course you can remove it, just make sure everything is turned off first.
Make sure you know your radio unlock code if will be needed.
If it just needs charged, it's simpler to connect charger without disturbing the battery and cables. Again, make sure everything is turned off before charging.
Old Dec 14, 2017
MW35's Avatar
Thank you for the reply, I need to take the battery off for about 24 hours to fully charge it, I do not know if I need a radio code that's why I'm asking, the vehicle is a 2008 the one with radio molded into the dashboard, I can't see nothing in the manual relating to a code, but I don't want to take the battery off to find out I need a code and do not have it.
Old Dec 14, 2017
Over on this side of the pond, if the radio face has a blinking red LED when the car is turned off, then it's a anti-theft type that can lock when the battery is disconnected.
IDK if that holds true on your side of the pond.
If you can reach the car with the charger I'd just connect it where it sits. Don't turn anything on while the charger is running.
If the battery has already flatlined completely dead... that's the same as disconnecting it
Old Dec 14, 2017
MW35's Avatar
There's no blinking red light on my radio when the ignition is off, but just to be safe like you said I think I'll just run an extension leads to the car on the side of the road and charge the battery on the vehicle.
wallydude03
May 19, 2008 01:51 PM
WiseRabbitSays
Mid Atlantic
16
May 6, 2008 08:00 AM
cpruitt
Buy, Sell, & Trade - Archive
May 2, 2007 08:08 PM
cambo
Jun 11, 2005 12:22 AM
