Clock and date and year reset problem. [cause found, need solution from Honda]
We have owned our 2007 Civic Hybrid since it was new. Today noticed clock was wrong. I have had to reset clock before and had no problem. But this time it will not reset. I have tried and wife has tried just in case I was missing something. It will not go into mode where numbers flash to reset time or am/pm.
Also date and year has defaulted to January 1, 2002. When I set it to Jan. 3 2021 it doesn't hold date reverts to Jan. 1, 2002. This is interesting since it is a 2007 Honda Civic Hybrid.
I am confident I am following owners manual directions on resetting the clock, seems as there is another problem.
Has anyone else experienced this same problem?
re: Clock and date and year reset problem. [cause found, need solution from Honda]
I'm having the same issue with a civic 2008 premium system. stuck on January 1, 2002 and around 5pm. no matter whatever I do, auto or manual, I can't change the time. It's like a contract expired, and no longer getting updates on the time/date.
I’m having the exact same problem in both my 2010 Honda Civic Hybrid and my 2007 Honda Odyssey. The civic is stuck on Jan 1 at 1am and the Odyssey is progressing with time of day but is 3 1/2 hours off and won’t let me change it, when I try it reverts to midnight. Both issues occurred at the start of the new year.
I will probably end up living with it until someone actually knows of what the fix is. I would also like to know approximately the cost of the fix before I take it into Honda. Shop hours are too much to just take it to Honda and let them scratch their butts and say we're not sure.
Calendars repeat every few years, I thought it was every 7 years but it's more complicated. 2011 is apparently the same as 2022 so try setting it to 2011 and see if it will function.
2007 Honda Civic Hybrid with navigation and XM satellite radio. Vehicle has about 83K miles, is serviced regularly, and is in excellent condition. Nav disk 6.81a in use. The diagnostics for the navigation system reports that all components are normal. There is no damage to the satellite antenna.
*Like other reports here, the clock on my nav system has been unresponsive to automatic or manual adjustment effective January 1, 2022. Since, the clock restarts at 4:00 everytime the ignition switch is turned to the "ON" position. There are no combination of buttons, selections, or otherwise that make a difference.
*Have reset the XM satellite radio. No change in the clock's operation.
*Have attempted to reset the nav system. No change in the clock's operation.
*Did all of the VIN and ID number issues. No change in the clock's operation.
*Contacted SiriusXM, did all they asked. Their conclusion was that "it is a honda issue, take it to a dealer."
*Today, disconnected the battery, waited five minutes (hysteresis), reconnected, entered anti-theft codes anew. No change in clock's operation.
*Found a download button in the Nav System, under version, SNAZ-2, downloaded, system seemed to do an update. No change in clock's operation.
This appears to be an issue common to us all. Question is, is it commenserate with the Y2K issue of 2000 in either in car gear or is it a satellite link issue?
Thank you,
Joe
I have a 2008 Civic Hybrid and it did the exact same thing. I guess Honda didn't figure we would still have the cars after this many years. At first I could re-set the clock but it wouldn't stick, but now it doesn't even give me that option. I guess I'll have to take it to the dealership.
Joe,
I have exactly the same year and make. It does the exact same thing! Did you ever find a resolution?
Thank you,
Tara
Thank you,
Joe
Alot of people were in the same boat as you, to include myself. I dug around and found the issue is with the programming and GPS signals, today, 8/17/2022 I started my 2008 honda civic and the time actually changed, I was able to set the time and keep it set even after a shutdown and restart. However, my calender still is not changing, it's so far locked to Jan 1 2002, no matter what I try I cannot get that changed, hopefully someone knows how to do that. But at least the time is accurate now.
Anyone know how to correct the calendar issue? Thanks!
This year,2022, my 2007 Honda Civic w/ Nav started at 2 pm every time I'd start the car - just like others here. When I went to Clock or Setup, I noticed a Done button was grayed out. Couldn't get past it; couldn't set the time. Always 2 pm. Yesterday, for no reason, the clock WAS ON TIME! No idea WHY! But the date was January 2, not August 21, 2022. Have gone into the Nav but can't find a way for the Calendar to lock on August 22, 2022 (today)! Clock works, but the Calendar won't or can't hold today's day!! The Calendar's Done button is grayed out.....
Re: Clock and date and year reset problem. [cause found, need solution from Honda]
The Solved suggestion here does not work ...
Ah, well ...!!!!
Same exact issue on my 2007 Civic Si coupe
Time is now reading correct (since sometime in Aug 2022) but date is not possible to change.
My corrective action was to put phone mount hanging directly in front of the touch screen for this car - hahaha.
