Electronics Post information/questions/Issues about Electronic parts here.
5 min delay timer circuit for the trunk light
Old Jun 29, 2020
emich's Avatar
emich is an unknown quantity at this point
where to buy 5 min delay timer circuit for the trunk light? My wife keeps leaving the trunk open and I am sick and tired recharging the battery.
Is building one the only option? Thanks
Old Jun 29, 2020
BrotatoChip's Avatar
Super Moderator
Re: 5 min delay timer circuit for the trunk light
How bad do you need the light in the trunk? Could just remove the bulb.
Alternatively, swap it with an LED. I left my trunk open all night once, started perfectly fine the next morning.
Old Jun 29, 2020
emich's Avatar
Thanks for the LED bulb idea.
Old Jun 29, 2020
there's a bunch of "programmable" in-line times on amazon. By programmable, you can set them to whatever time you want. Some, you'll have to figure out your own enclosure for it. some are self-contained.
Here's a self-contained one, 0.1s to 9999hr adjustable
definitely look at the LED route though. Not all LED bulbs are created equal, I should add, with regards to brightness/usable light, at least. Want better visibility, stick with something with a warmer color temperature (3000K is straight up amber/yellow, 4000-4500K-ish will give you a slightly yellower than sunlight color, 5000K-5500K will give you natural sunlight color, 6000k and up, you start getting blue hues). Just to add to what @BrotatoChip said, I left my map lights on all night once. Car started up just fine. Here's what I'm using for my map/dome/cargo lights. They're stupid bright for the overhead lights. However, the way the cargo light is oriented in the cargo area of my hatch, I wanna go with something different for better light usage
Old Jun 29, 2020
emich's Avatar
Thanks Very informative.
Old Jun 30, 2020
Super Moderator
If you do go the LED route don't get one with a built in load resistor. If you do it will act the same as a regular bulb.
Zoto724
Lighting
Feb 24, 2005 04:40 PM
civicguy777
Feb 11, 2005 12:45 PM
01CivicL
Dec 31, 2002 01:48 PM
CivicSouldjaEX
Jul 26, 2002 09:11 PM
darelldd
Feb 16, 2002 02:32 AM
