- turn signal problem
- 94 Civic DX starting problems, need help!!
- 91-92 Exhaust question
- 88 civic hb
- b18b1 Cranks, but won't start
- Trying to meet other 95 civic owners or pretty much anyone to chat with.
- replace oxygen sensors with header?
- 98 LS B18 timing belt failure
- new project first honda
- Engine code ?
- exhaust questions!!
- dpfi to mpfi conversion
- How do you remove the starter Relay from a 1992 Civic DX
- Needing Parts..thanks to plow
- new tire suggestions!!
- i got the cancer prob
- 4-1 or 4-2-1 header d16z6?
- Need some swap advice
- Engine Stalling, Need some tips
- need a guru to confirm this
- clutch interlock plastic piece
- Left the lights on... battery died
- Left hand drive SIR?
- First Honda,Craigslist.
- Gsr pistons and rods in a LS
- b20b with b16a head
- 1991 civic centre console
- obdo dpfi to obd1 mpfi
- H23A dohc non-vtec swap
- Post ur 89-92 hatch's!!!!!!
- Biggest offset that fits on an 4door EG?...15" and 16"?
- 93 si k24 help
- Will Axis OG Bonzai's 15 or 16x8 fit 1995 civic?
- Clutch issues - 95 Civic DX Hatchback
- Car wont start (sometimes)
- AEM Intake mani problem HELP
- Need help with Front end Vibration 91 civic Hb DX
- power steering
- What interchanges with my 87 Civic Si??
- heater problems...
- 92 Honda civic idle fluctuating wildly.
- 93 civic run rough when hot
- 1990 Honda civic ex 4WD wagon
- speedometer/ speed sensor help!!
- Need some ideas for my 89 hatch
- door lock civic lx 89
- oil clearance for rod bearings D16z6
- Oil on plug 1
- Painting whole car
- intermittent rough idle....stall
- offset rims for civic
- 85-87 honda civic relay problem
- civic issues possibly solved...
- Need help with engine info and options
- Finally stopped the oil leak and cleaned the engine
- 1989 Civic, stumbles & miss firing
- D15b Civic 92 Vtec some problems.
- head swap on a 93 civic
- What RPM should i coast at to save fuel?
- gonna sound dumb....but ill ask
- D16Z6 Upgrade Options??
- 95 si Craiglist special!
- D15 specs for rebuild
- B18b valves in b18c head?
- 2 hoses on left side of motor???
- Swap Manual Mirror For Electic Mirror W/LED
- Which is the best motor to swap into my 93?
- how did i lose a sunroof?!?!?!?!?
- Defroster does not blow out vent
- Weird Idle Surge Issue
- Wanted to know what you guys thought?
- Distributor/Ignition coil firing problem. Fried Coils!!!!
- 1995 dx
- New here, and this is my project.
- Starting to think I am fixing the wrong problem
- Ran codes for engine check light
- New here.. Need help :)
- 95 DX coupe-Whats wrong with my gas gauge
- still the same crapola
- 2 problems 1 the idle is jumping 2....
- 1988 clutch install, can't get transaxle out...
- no power an back firing through intake d15
- Need some swap advice (D16z6 to D15b)
- 95 DX hesitating and surging in 1st and 2nd gear
- My 95 EG project
- throttle lever/cable? problems!!!
- what do i need for a motor swap?
- 94 civic driver side hid light not working
- 1994 Civic frusteration!!!
- High temp issues
- Help please 94 civic question
- (video)no gas when i press the pedal? d15b please help
- Weak acceleration, strong odor.
- Fuel tank not venting?
- 95 ex coupe cv shaft ?s.
- Cruise control help
- 95 civic ex tip and facts
- d16a6 issue
- 95 Civic Vent control issues
- 1992 Honda Civic - Won't Start
- cold engine issues
- Code 1 O2 Sensor / D15b Vtec
- Good motor swap websites?
- d15b2 mpfi to dpfi question
- Why can't my poor little Civic pass E check?
- v-tec head in d16a6?
- Help
- Code 1 Oxygen Sensor/ D15Bvtec
- 86 civic fuel evap pressure test fail
- 86 Civic 1300 fast idle?
- 86 Civic 1300 catalytic converter
- Timing issues...
- Im a noob
- Headgasket failing, doing mods; what CR works with 91 octane?
- Car died while driving, won't start. Need help!
- 93 civic with h22a what pipeing do i use
- for my 5th gen. 95 civc lx engine help
- Car Stolen / Recovered Need Info Please
- stock p28 with USDM gsr
- 95 Civic CV boot torn. What should I do?
- Speedometer Help! 95 Honda Civic
- 5th Gen Cat.
- GSR ENGINE CRACKED by MOTOR MOUNT BRACKET!!! HELPPP!!!
- No fuel or spark
- Please helpp!!! Asap!!
- Mini me bogg
- what does it take to put a gsr motor in a hatch
- emengency question
- emergency question
- 95 Honda Civic Starting issues
- no spark, need help fast!!
- 93 Civic Key problem?
- how much oil in my a/c?
- 93 Gauge cluster lights not working? :S
- H2B build
- 92 civic swaybar
- 95 coupe....irritated
- 1992 Civic LX. Wierd problems!
- too slow when my civic ef driving in flyover
- timing issue 82 1300fe
- 1995 Civic DX Hatch, patience is running thin.
- Honda engine
- IAT: cnt find Intak air temp sensor!
- 95 civic swap need help bad please look
- 95 civic
- Noob question, auto tranny fluid 91 DX
- identifying a swap?
- Help! '95 Civic LX Head Gasket - Any Successes???
- timing marks
- speakers will turn off suddenly every few seconds of play. help?
- complete rebuild help
- front and rear strut bars
- interior neon music flashing lights help please?
- Hard start
- 94 civic dx starting problem
- Putting a k24/k20 hybrid in this civic!
- h23 swap need help
- Blox Lower Control Arms
- 95 Civic EX - What are all of these exhaust gaskets?
- EG Cluster bulb location diagram.
- Footwell LED lights wiring diagram DIY.
- 1994 Civic Si (Hatchback). Worth Buying?
- 93 civics si rear speaker size
- 94 Civic Randomly Stalling then not starting
- Adding a glove compartment light?
- First Time Honda Owner ! :D EJ1
- 90 civic si hb seat removal
- new civic owner
- 91 civic sedan swap
- 95 civic lx still has miss
- Being a typical Noob,
- need help for 95 civic's idle
- Stereo wont turn on
- Aftermarket rear speakers
- 93 civic dx hatchback BIG problem HELP!!
- 92 SI hatch; Help?
- 1991 CRX SI - AC/Engine questions
- 1995 Civic The Case of The Disappearing Coolant
- 89 civic LX problem
- 92' Honda civic Lx
- '96 center console in a '95
- Civic Worth???
- auto to 5spd conversion
- 94 civic headlight problem
- Setting ignition timing without timing marks
- 91 Civic Manual H/B not starting need help identifying something Pics Included
- Wheel choice
- 91 civic hatch acting real weird
- Help with locating Halo Headlight screws
- replaced o2 sensor and still throws code 2
- Strange Rattling :s
- Broken bolt on valve cover
- A/c belt size (d15b v-tec)
- DPFi to MPFi swap idle problems
- 91 Automatic-Filter Yes/No- What mileage do you have on your automatic?
- 92 cx issues
- 92 civic wont start
- need some help for 95 civic
- 1990 Civic si add a/c?
- '83/'91 Southwest Michigan Free filters
- what engine parts are compatible with D15B7?
- Civic 95' Windshield Replacement
- 84-87 Civic HUGE front bar wanted
- Swap! Please help! Major question!!
- Working on my first car, pointers?
- Back at it again! Newbie...
- 95' Ex Coupe Auto VTec
- Stock 95' EX Coupe VTec Automatic
- 1991 SiR not getting enough power, its not the alternator
- Rotor Button Screw Size?
- Upgrading my 1990 DX hatchback
- wipers working on intermittent setting only
- carb to fuel inject
- 1991 Civic Igniter Question
- Noisy Fuel Pump
- Just Bought a 95 Need Help
- How to reupholster 93 Civic EX car Seats
- AC won't stay on for long
- 1991 ef hatchback DX transmission
- Now onto the A/C issues...
- 91 civic hatchback SI Problem plz help
- 1976 Civic cvcc question
- 92 civic overheating
- Buying a 94 Civic ex
- Transmission weirdness:
- vtec failure?
- Radiator fan issues
- Quick exhaust question . . .
- B18C Engine Swap
- 1992 Civic Hatch won't start....sometimes
- salvage tranny advice
- Oil on my Spark Plugs
- b16 or k20
- Tire Rotation question????
- 89 Hatch
- Starting problems, and idle problems
- HID Question
- timing belt boom!
- Fuel issue?
- skunk2 springs for sale
- First Honda Ever
- 1990 honda civic hatchback questions need help
- What does this mean? (CEL code 41) 95 ex cpe
- What should I pay???
- off road fun
- newbie with a no start problem
- Radiator Fan Not working
- Low pressure a/c port in 1995 Civic?
- new to honda, need some knowledge
- intermittant is now permanent
