1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
What RPM should i coast at to save fuel?
Old Nov 26, 2010
starblades's Avatar
starblades is an unknown quantity at this point
Engine bogs around 1400 rpm.
I cruise around 1750 and shift at around 2250. Its a 5M/T. Where am i supposed to cruise and shift at? cuz im getting 24mpg which is really low.. and i drive slow... Maintenance is up to date
fresh oil change, engine timing ok, air filter ok, spark plugs/distrubutor cap/wires ok, new fuel filter, brakes ok, new tires, wheel alignment ok, no check engine light
see the thing is, i have other friends with civics and they drive way harder than i do.. and they get 28mpg
1993 civic. 1.5L On the back of the car it says its a EX trim, but i looked up the vin and it says its a LX trim so i dont know...
Old Nov 26, 2010
J-Master Flex's Avatar
J-Master Flex is an unknown quantity at this point
Re: What RPM should i coast at to save fuel?
I own a DX, so my cluster doesn't include a tachometer. But I usually shift at 10mph (1st-2nd), 25mp(2nd-3rd), 35mph(3rd-4th), and 45mph(4th-5th). Get's me 35mpg in the winter, 39 in the summer.
If you're not getting above 30, and your car is completely stock, then there's definitely a problem you need to look into.
Old Nov 26, 2010
MindBomber's Avatar
Live for the Twisties
Add LC20, your car is getting older so it might simply be that the fuel injectors and such aren't working as efficiently.
Also consider changing your 02 sensor if you haven't done so, that will give a noticeable improvement in fuel efficiency.
Wild Cranker
May 19, 2015 06:10 PM
mrcell24
May 19, 2015 10:02 AM
Ninetyatecivic
May 9, 2015 07:48 PM
davidpaustin
May 7, 2015 05:08 PM
davidpaustin
Apr 30, 2015 11:20 PM
