1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
94 civic driver side hid light not working
Old Nov 3, 2010
EJ94's Avatar
EJ94 is an unknown quantity at this point
Unhappy 94 civic driver side hid light not working
I doubt anyone has had this paricular problem. Doesn't hurt to ask though. Ive installed in my 94 civic ex an hid kit. The passenger headlight works fine. But the driver side turned on for a couple of days and then went out causing the fuse to short. Anyone have an idea or suggestions why this may be happening? It doesn't make sense for one headlight to work and the other to not. I don't know what to do. Ive gone through three fuses. My buddy had an extra ballast and let me have it but it did the same thing. By the way does anyone know if the 94 civic ex has a specific relay for the headlights? Maybe that's the problem? I appreciate the help.
Old Nov 3, 2010
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
Re: 94 civic driver side hid light not working
Sounds like a short on that side. Recheck the wiring.
Old Sep 18, 2012
bissongreen's Avatar
bissongreen is an unknown quantity at this point
I had a similiar issue.....I installed them myself and was working fine for about 8 month....and then the passenger stopped working....after lots of trouble shooting it actually was the ground not properly connected!!!.....so to make a long story short, the ground from the ballast is strongly recommended to be grounded directly to the car battery....My problem was solved!!!!!!!!......I had it grounded to the headlight bolt, which appears to not have proper ground......Hope this will help.
Note: the ground wires from the ballast supplied is not long enough....you'll need to get's some wire to extend to battery.
Cheers!!!!!!!!!!!
Old Sep 19, 2012
i had this problem too and turned out to be loose connections to the relay. i soldered them in and back to normal.
Fastfebur
Apr 22, 2015 01:37 PM
ej8
Apr 13, 2015 06:36 PM
EXWisdom
Nov 5, 2001 10:24 PM
sonsonzai
Nov 4, 2001 12:52 PM
WeRkX
Nov 1, 2001 10:33 PM
