1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Setting ignition timing without timing marks
Old Aug 10, 2010
Civvyftw11's Avatar
Civvyftw11 is an unknown quantity at this point
Hey,
I recently replaced my dizzy and I went to set the timing but there are no marks on the crankshaft pulley, I thoroughly searched the crankshaft pulley and found nothing. My question is whether there are any other ways to set ignition timing.
Old Aug 11, 2010
b18b1civic94's Avatar
b18b1civic94 is an unknown quantity at this point
Re: Setting ignition timing without timing marks
find ur top dead center of piston 1 and leave it there
is it sohc or dohc?
Old Aug 11, 2010
Civvyftw11's Avatar
sohc.
Ill giver a try tomorrow morning and let you know how it went, thanks for the help, I've posted this question on a few forums and this is the first response I've gotten haha
Old Aug 12, 2010
02civicsi02's Avatar
Low and slow!
When you do your timing the marks line up at cylinder 1 TDC. In which this case you do not have marks then just set it to TDC on cylinder 1. An easy way to check if the cylinder is at TDC is take the plug wire out and spark plug and find something small and long that ill reach down in the cylinder and turn the crank. When it starts to go down it passed TDC so rotate it again till it reaches the top. Then you should be good. Try it out and see if she runs good. If there is miss fires and stuff then you might have to try it again but you should be fine.
Edit: I forgot, you can also do your timing with a timing light.
Old Aug 12, 2010
Civvyftw11's Avatar
I set piston 1 to TDC and the car seems to be running fine now, I tried using a timing light but there were no visible markings. Anyway it all worked out, thanks for the help!
Old Aug 12, 2010
Low and slow!
Ok glad to hear, let us know if the car starts to run different or has some misfires or something.
jbradley4809
Apr 7, 2017 04:23 AM
carid
Apr 30, 2015 07:00 AM
dragonsblood
Apr 27, 2015 12:28 PM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
AL
Oct 18, 2001 03:01 PM
