1992 Honda Civic - Won't Start
Subscribe
Oct 23, 2010
Have a 1992 Civic EX 1.6, it is currently having a 'not starting' issue, more not starting than starting right now. Has anyone heard of the issue being in the ignition switch? Did a continuity test on the end of the switch plug, as described in Hayes Repair Manual (page 12-6). It passes all except the key out position, should be continuity between the BLU/White & BLU/White (key & Gnd).
Have changed out distributor, distributer cap, fuel pump and the main relay. When it doesn't start, the fuel pump won't pump, can't get it out of park-brake isn't allowing and the check engine light doesn't go off; no issues with the lights, windows, etc. When it gets started it runs great!
Nov 19, 2010
Re: 1992 Honda Civic - Won't Start
May want to look into replacing the Coil and Ignitor, I've been told to replace both together bc they typically go out hand in hand
Subscribe
