1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
complete rebuild help
Old Sep 15, 2010
williamanastasi's Avatar
williamanastasi is an unknown quantity at this point
Question complete rebuild help
I have a 93 civic lx with a d15b7 and an automatic transmission. i want to still be able to use this as a family car to some degree, but want the most out of my car, and to be able to get another good 20 years out of her. the first thing i need to know is what i need to do to rebuild the engine...
THX
Old Sep 24, 2010
phil_89's Avatar
phil_89 is an unknown quantity at this point
Re: complete rebuild help
well i just rebuilt mine its not cheap... but can be... if u do the work your self...
you'll have to pull the engine out and brake it down...
you can replace your valves... and your piston rings...
also all the bearings on your crank... and if u have over 140,000 miles or your close to it i would replace your fuel pump while your at it...
also u can get new freeze plugs put in....
that would do some good... also if your not using synthetic you should start.... i use synthetic + marvels mystery oil they sell it at target and Wallmart's.....
buy new belts "timing belt too" and hoses..... and i think thats most of it... if i missed anything just let me know... but the main thing replacing your valves,bearings and your timing belt....
Old Sep 24, 2010
02civicsi02's Avatar
Low and slow!
When rebuilding a motor you will need to take the motor out of course and put it on an engine stand, makes things so much easier. Take it apart and clean it really good. Best thing to use is brake cleaner, it gets rid of almost any kind of grease and it just evaporates. Now you will need a good set of tools to do this to and knowledge.
Whdn taking it apart remember where everything goes and make sure you have a torque wrench and know all the specs. When everything is out you will need to inspect everything especially pistons, valves and the cylinders. when doing a rebuild you will mostly need head studs, piston rings, timing belt, crank and rod bearings, and a new hole gaskit kit. You will need a honing tool also to hon the cylinders so the new piston rings will seat good. Make sure that on the rods that the rod bearings oil hole lines up with rod oil hole. Most the time they dont and need a little adjustment but a easy fix. You will just need to drill the rod bearing hole a little bigger. After checking everything and it all seems good with no dents chips or so forth then do the required things and put it back together.
JohnnyBxo
Nov 12, 2015 03:04 PM
naokigoffi
Aug 30, 2015 06:19 PM
ttamrekab
Aug 23, 2015 07:45 PM
Zugor
Aug 21, 2015 08:36 PM
estes53
Jul 20, 2015 10:43 PM
