1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
1989 Civic, stumbles & miss firing
Old Nov 28, 2010
peterstransky's Avatar
peterstransky is an unknown quantity at this point
Greetings all, first post here
My nephews 1989 civic has a wierd problem where if driven at a consistent RPM for say two or three miles, it starts to misfire badly. To get it to stop, you have to slow down, shifting iinto the lower gears, and it after a few minutes shifting around and chaning the RPM.s it will recover.
The odd thing is that you can drive it around town all day and the problem does nto occur. By that I mean, if you are shifting around as you would in around town traffic, no problem. But get out on highway (or a local road) and ride alond in topo gear for a few miles and the problem starts.
Some particulars:
1989 civic hatchback, five speed (of course).
dual ppoint programed fuel injection
228,000 miles
AC, but not hooked up
New air filter on a cold air tube (the old one was clogged, but a new one didnt fix the issue. Also ran it with raw air (no filter) but no change in behaivior)
Replaced all the vacum lines that I could find, accept the ones on the automatic choke (didnt change the behavior)
Happens with the engine hot or cold
Idles fine
Revs through RPMS smooth as silk when shifting
Thoughts?
Old Dec 7, 2010
BlueEM2's Avatar
Whachya lookin at?
Re: 1989 Civic, stumbles & miss firing
Moved to your generation subforum. Hopefully you will have more luck getting help here.
Old Dec 7, 2010
lazlong's Avatar
Sounds like a clogged fuel filter. If not that it could be your fuel pump is dying, bad fuel pressure regulator, or bad injectors.
CarStuff
Dec 6, 2020 12:52 PM
usajags84
May 10, 2015 08:11 AM
rcolosi
Apr 29, 2015 07:48 PM
cooldan1
Apr 23, 2015 10:49 AM
usajags84
Apr 10, 2015 09:54 PM
