1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
DPFi to MPFi swap idle problems
Old Aug 4, 2010
Guga's Avatar
Guga is an unknown quantity at this point
Hi guys, so im gonna expose my problem.
I have a d15b2 dpfi engine, 90hp and i bought a d15b vtec intake manifold that came complete with p08 ecu injectors throttle body etc...
So i wired the ecu, every wire except for the o2 sensor that i still dont have
the four wire one, and the vtec wires (no vtec head)
Then i got myself a dizzy, My old dizzy plug didnt have crank sensor wires (white and orange) so i took them from the ecu
Plug from the new dizzy
The wires that didnt have correspondence, but i wired them to the ecu.
Them o got a tps cuz my manifold didnt have one.
I switched the green and yellow wires in the tps, am i right?
I had bits of gasket in the head so i cleaned it as most as...my patience allowed me :P
But i left some bits there, and when i tightened it up as mutch as i can, i filled it with water and it was leaking :\
And now after all my idle is at 4000~4500rpm.... do you think that its from a leak in the intake manifold?
One of the nuts isnt tightened up, the bottom one cuz i just CANT tighten it up, i cant reach it, if i do reach it with the wrench it hits the manifold and i cant turn it... wich maybe is giving me a even bigger gap...
Any ideas?
Cheers
PS: If i disconnect the IACV plug my idle goes to 2000, but if i accelerate it blops, like stalls lol like is too much air going in and no fuel or something...with iacv connected its at 4500 but if i press the gas it accelerates even more, doesnt stall
beneditti
Jan 15, 2016 12:31 PM
zaboomafoozarg
May 30, 2015 09:21 AM
crowtoo
May 11, 2015 06:50 PM
jakeconnor
May 5, 2015 07:30 AM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
