1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Fuel tank not venting?
Old Oct 28, 2010
95EX's Avatar
95EX is an unknown quantity at this point
Everytime i opened my gas tank it would release a ton of pressure...thought it was a bad cap so got a new one...same problem.
I will also smell fumes after driving it sometimes and when i take the cap off it releves a ton of pressure.
Is there another vent for the tank someplace?
Old Oct 28, 2010
Civvyftw11's Avatar
Civvyftw11 is an unknown quantity at this point
Re: Fuel tank not venting?
My honda had the same issue, don't know if there is another vent for the tank, kinda doubt it, but I wouldn't worry too much about the issue, my car ran fine and it had the same kind of pressure release whenever I took the gas cap off. From what I know, this is a somewhat common problem on older hondas.
Old Oct 28, 2010
95EX's Avatar
i did some research and found theres a solenoid by the charcoal canister. I dont think the canister can be the issue but maybe the solenoid?
Anyone know how to test this???
Old Oct 28, 2010
usually if there is a problem with the EVAP emissions system, the engine light will come on. pressure release from the gas cap is normal. many caps actually say 'open slowly, fuel pressure danger' or something. during the time you drive, some of the trapped vapors are burnt in the engine, but there are always some vapors stored that may get burned next time you drive. it is not a constant process. if you have pressure being released, it means your gas cap is good. a leaking cap will not hold pressure.
Old May 23, 2011
kbook's Avatar
kbook has a spectacular aura aboutkbook has a spectacular aura aboutkbook has a spectacular aura about
I have the same problem except I drive the 7th gen. I hope there is no problem. I am just annoyed by the smell.
Hrddrvs
18
Aug 17, 2015 01:08 PM
Civicircus
Aug 6, 2015 11:58 PM
Green02civic
Jul 27, 2015 10:48 PM
shaejb15
Jul 27, 2015 03:48 PM
jody501
Jul 10, 2015 11:01 AM
