1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
2 problems 1 the idle is jumping 2....
Old Nov 7, 2010
95civicSauls's Avatar
95civicSauls is an unknown quantity at this point
Hi i have a 95 civic dx coupe i have 2 problems when idle it jumps up and down the 2nd 1 is the car seems to jerk when i barley press the gas then i have to really push it so it wont do it. the car is auto but it dont happen all the time please help and i was woundering where the vaccums where so i can clean them thanks
Old Nov 9, 2010
YSIDRAG's Avatar
YSIDRAG is an unknown quantity at this point
Re: 2 problems 1 the idle is jumping 2....
There are a few diff things that can cause the idle to "jump"
1. LOW COOLANT
2. VACUUM LEAK/LEAKS
3. IDLE AIR CONTROL VALVE.
Check to see if you are low on coolant first off, if not you can look at all vacuum line make sure there not broke or anything.
Best way to check is with a smoker witch you would have to take to your local shop to have them do it.
IAC valve is the most common reasion this happens, IAC on your car is bolted to the back side of the intake, it has coolant that runs through it. Un bolt it and check to make sure it isnt clogged up. youll see a srean on the inside it will be black with carbon. just spray it down with car cleaner and scrub it lightly with an old tooth brush. One of these should take care of your problem.
Jay
Fabricated Performance
Old Nov 10, 2010
phil_89's Avatar
phil_89 is an unknown quantity at this point
^^^ ya make sounds like coolant is low..... and its auto... so cheack ur trany oil
Old Nov 13, 2010
will do thanks
Old Nov 21, 2010
bluhonda's Avatar
bluhonda is an unknown quantity at this point
check the idle air control valve on the bottom of the throttle body. take the plate off the back theres two 8 mill screws there. next theres a white ball with two slits on it. now take a flat head driver and whine it down.put it back together and your all done. start the car of corse and she back to norm. have fun
Old Nov 22, 2010
530matt's Avatar
530matt is an unknown quantity at this point
sounds like could be throtle postions sensor (TPS)
mikemc422
Aug 9, 2018 05:41 PM
zaboomafoozarg
May 30, 2015 09:21 AM
lildoo
May 9, 2015 09:44 AM
jakeconnor
May 5, 2015 07:30 AM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
