1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
85-87 honda civic relay problem
Old Nov 30, 2010
brandonadams's Avatar
brandonadams is an unknown quantity at this point
the lights dim (headlights, dashlights, and dome light), the heater stops, and seems to loose all power when anything is used. its like the battery is drained completey and stops running. but when all the accessorys are turned off idles and runs great. accessory relay? or whats the deal
Old Dec 1, 2010
"goose"Jay's Avatar
"goose"Jay is an unknown quantity at this point
Re: 85-87 honda civic relay problem
first off your battery isnt being used once you idling its all the alternator. start by having that tested at your local advanced auto. Sounds like the culprate.
Old Dec 1, 2010
yeah its not the alternator already was tested. and the battery is being drained because it dies and wont start
Old Dec 1, 2010
phil_89's Avatar
phil_89 is an unknown quantity at this point
...that sucks... do u have a sound system.. amp and ****.. if u do then u might need to get a capacitor to help store the powere while ur system is on... and it will keep your lights from dimming.. and ****
Old Dec 1, 2010
yeah it just has a stock radio. it drives fine if the lights and accessories arent on but thirty mins or less it starts dying after i use anything
Old Dec 3, 2010
"goose"Jay's Avatar
sounds like youve got some weak wires somewhere id trace them. You wouldnt happen to have any toggle switches or anything hooked up would you? The wire that comes from the alternator to the fuse box (at least in 92-95 it does) wont show up in a voltage test, try checking that and make sure its not broken or dropping voltage.
Civicman92296
Apr 23, 2015 09:22 PM
alexkharden
Apr 23, 2015 07:13 PM
paulnguyen
Apr 20, 2015 01:33 PM
jessicakaybby
Apr 20, 2015 12:11 PM
dooner24
Apr 14, 2015 07:51 PM
