1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
D15b Civic 92 Vtec some problems.
Old Nov 27, 2010
Vtec 92 boss's Avatar
Vtec 92 boss is an unknown quantity at this point
Okay, I recently bought a Honda civic 92 vtec-e for $750 nz, which is cheap. On the way home, temp was rising past the H. Turns out was a blown head gasket. But also the radiator wasn't turning on. Head lights didn't work. Brake lights stayed on. Also car sometimes smokes a **** load. Like, so much that if a piggy sees me they'll pull me over.
So, I replaced the head gasket, fixed the brake lights, replaced the headlight switch, and now it's just the radiator.
My mate connected the radiator directly to the battery via a wire that I have to disconnect all the time. It turns on etc, but wouldn't by itself. Does anyone know the problem here? I'm almost sure it's not the thermostat.
As for the smoking, it's not a blown head again, could it be a cracked head?
Old Nov 27, 2010
phil_89's Avatar
phil_89 is an unknown quantity at this point
Re: D15b Civic 92 Vtec some problems.
smoking.... ur piston rings are fried... well thats what it sounds like have a compresion check done... as for ur fans.... turn ur ac on... if it dosnt come on it might be the relay....
u can check your therostat by puting it in a pot and heat it up...
Old Nov 27, 2010
speedy25's Avatar
speedy25 is an unknown quantity at this point
How can you hook up a radiator to the battery. Radiators arent electric! I'm guessing you mean the rad FAN(S). I dont have wiring diagrams for 92 but the usual setup is a rwmp sensor in the rad turns the fans on and off. Removing the connector and/or shorting the connector turns the fan on. There may also be relays in the fan circuit. Find the right manual to confirm your system.
-SP
Old Nov 28, 2010
Possible problem, my car has no ac fan lol. And yeah, I mean the radiator fan is hooked to the battery.
Old Nov 28, 2010
phil_89's Avatar
well what u can do is... wire it to ur fuse box... that way when ur car come on it comes on... and when u shut off ur car it shuts off... thats one way but not the best... the best would be to figure out what's wrong with it or just rewire it
Old Dec 1, 2010
"goose"Jay's Avatar
"goose"Jay is an unknown quantity at this point
yea that way tends to nuke fuses frequently lol. Id say trace wires and rewire what you have to, you gotta also think if you ever go to sell this people will be less likely to buy with half a** work done. No offense btw lol
Old Dec 1, 2010
"goose"Jay's Avatar
also check the temp sending sensor right on the thermostat housing those are NOTORIOUS for having alot to do with radiater fan problems. May even wanna check the temperature sensor on the head as well.
Old Dec 1, 2010
phil_89's Avatar
lol iam doing a wire tuck so all my wire is new... just starting for the plugs and then going out... "new under the hood..." its still a work in progress
Old Dec 3, 2010
"goose"Jay's Avatar
hey ya cant go wrong with tucks man. I just wouldnt ever tap into fuses unless it was an inline. 1 small problem in electrical generally leads to one huge one/.......or at least in my case it does.
beneditti
Jan 15, 2016 12:31 PM
LionSpratt
Apr 26, 2015 01:02 PM
Tybonater
Apr 24, 2015 07:03 PM
MamaBear2015
26
Apr 16, 2015 11:08 PM
CapYoda
Nov 11, 2001 05:17 PM
